3rd Gen GK Specific Fit Engine Modifications, Motor Swaps, ECU Tuning Sub-Forum Threads discussing engine mods/swaps/tuning for the third generation GK Honda Fit.
oil catch can catch 22?
Old Dec 20, 2020 | 04:12 PM
bill bosco's Avatar
just got my oil catch can , nicely built unit , has an internal baffle tray and filtered inlet , and it's own little dipstick , the snafu being , it's winter and the included paperwork recommends not
using it when the temperature is below freezing . the moisture buildup in colder temps can cause the lines to freeze up . catch 22 ?
Old Dec 20, 2020 | 08:20 PM
joneill4's Avatar
I have never heard f a PCV hose freezing. I don't see how a catch can would make a difference.
Old Dec 22, 2020 | 01:19 AM
BMWguy22's Avatar
Considering the issue with Honda is "fuel dilution" on their engines, I don't think this is an issue.
Mostly since fuel has a much lower freeze point than water.
So as long as you are running you engine up to proper operating temp to burn off the water in the crankcase, you'll be fine.
It's that pesky fuel in the crankcase that poses long term issues!
Jcasenave92
Nov 8, 2020 01:58 PM
Ogrelode
Feb 24, 2019 09:14 PM
Eugene.Atget
Dec 11, 2010 07:21 PM
Margelous
Jul 20, 2010 11:42 AM
Buzzbomb
Feb 19, 2010 02:55 PM
