3rd Gen GK Specific Fit Engine Modifications, Motor Swaps, ECU Tuning Sub-Forum Threads discussing engine mods/swaps/tuning for the third generation GK Honda Fit.
Air intake till turbo setup
Old Jul 30, 2020 | 05:07 PM
Rachet_fit's Avatar
Current setup till I turbo
bunch of cheap autozone connectors and piping, the original airbox piece that holds the the airflow sensor Meshed to a carbon fiber tube ( the radius and curve from a bottle from the gas station forgot which one ) wrapped in heat tape to help protect it from the heat, and a cheap spectre air filter ( unless someone can testify with evidence they are good filters )
Heat shield mounted to engine block is a sheet of aluminum, the other side of it has more heat tape to help keep the header heat away from intake...
I like it and think it sounds good, with 117F degrees outside and WOT on the Highway no check engine lights but I’d love to get it tuned, and find a local tuner for when I turbo, trying to make the best sleeper/beater fit around
Old Sep 21, 2020 | 10:24 PM
NWCH's Avatar
Or just buy an AEM.
Old Sep 22, 2020 | 09:55 AM
JorbNorb's Avatar
Hot air intake.
All those filters let a bunch of junk into the engine.
Old Sep 22, 2020 | 11:10 AM
NWCH's Avatar
Originally Posted by JorbNorb
Hot air intake.
https://youtu.be/sJ3L-E-ufYo
You sir are smoking on crack pipe.
Old Sep 22, 2020 | 11:26 AM
JorbNorb's Avatar
Nah, I'm at work. Been around long enough to know those performance filters do not filter well. Also been around long enough to know that engine bays are hot. You do you, man.
Old Dec 27, 2020 | 01:26 AM
Rachet_fit's Avatar
Or just buy an AEM.
the aem set up costs more then my set up, and doesn’t manage heat better then the heat shield Set up I have...
as for engine bays being hot air zones, why do you think I kept the air scoop in the grill and drilled more holes to let more fresh cold air in, if my transmission is running hot enough to heat up the intake air we have much bigger problems lmao
but what do I know I’m just a mechanical engineering drop out who got a trade school degree in fabrication
*edit*
turbo build project started, in planning/ research and prep stage + parts collecting...
zfr846
13
Apr 14, 2022 07:58 AM
Cordizzle4life
34
Sep 21, 2015 11:33 PM
mikeGe82012
Apr 17, 2015 02:11 PM
th0m4svu
Aug 5, 2010 08:39 PM
sansar
Jan 15, 2007 09:29 AM
