3rd Gen GK Specific Fit Engine Modifications, Motor Swaps, ECU Tuning Sub-Forum Threads discussing engine mods/swaps/tuning for the third generation GK Honda Fit.
Lrptec l15b carbon fiber intake manifold
Old Aug 28, 2018 | 03:11 AM
LRPTEC's Avatar
Cool Lrptec l15b carbon fiber intake manifold
Product only suit for MT vehicle.
Ecu need to be remap,disable EGR, increase maximum rpm to 7500 at least.
Recommended to install valve springs, ensure the stability of the valve assembly after the engine maximum rpm is increased.
Easy to install.
100% dry carbon fiber PCM molding, high precision machining and Special bonding technology.
Light weight and good thermal insulating properties.
High strength to deal with the complex environment of engine.
Increase engine power,+13hp or more with OEM longblock,+20hp or more with high performance longblock.
Dimensions:412mm*266mm*184mm
Weight:3KG(without throttle )
test1:
◆High lift camshaft with valve spring.
◆CP 12.5 pistons with stock rod
◆60mm throttle
◆race exhaust
◆link force GDI ECU,8500rpm.
◆98 octane fuel
◆temperature 32 Celsius,IAT 55 Celsius
The oem manifold get 173.5hp.The carbon fiber intake manifold get194.5hp(tcf1.15).
test2:
◆OEM engine block(with valve spring)
◆race exhaust
◆link force GDI ECU,8000rpm
◆60mm throttle
◆98 octane fuel
The oem manifold get 153.6hp.The carbon fiber intake manifold get167hp(tcf1.15).
test3:
◆OEM camshaft(with valve spring)
◆60mm throttle
◆race exhaust
◆link force GDI ECU,8300rpm
◆98 octane fuel
◆temperature 27 Celsius,IAT 55 Celsius
oem manifold get 173.5hp.The carbon fiber intake manifold get 187hp(tcf1.15).
Old Aug 29, 2018 | 09:23 AM
LeFreakyBone's Avatar
Subscribed.
Old Aug 29, 2018 | 09:41 AM
GAFIT's Avatar
Intake looks sweet! What is this car going to be used for?
Old Aug 29, 2018 | 04:48 PM
evilchargerfan's Avatar
OH MY ...... any plans to mass produce and sell those?
Old Aug 29, 2018 | 07:39 PM
UnFitParent's Avatar
That’s gawgeous
I think that qualifies as engine porn. I’d buy a clear plexiglas hood so I could look at it all day. Just...wow
Whats up with the hp numbers though? Is that a Dyno from a souped 1.5t or something? 173 to 194?!! The Fit would be a rocket ship with 200hp... Itd be the si killer! (Or am I dumb, and those aren’t hp at the wheels numbers but something else entirely, related to the manifold)
Old Aug 29, 2018 | 08:39 PM
LRPTEC's Avatar
Talking
yes,being mass produced.
Old Aug 29, 2018 | 08:40 PM
LRPTEC's Avatar
It is used for track.
Old Aug 29, 2018 | 08:46 PM
LRPTEC's Avatar
Talking
All of them dyno from 1.5NA,The NA L15b engine has the potential to get the power.It is flywheel hp that i posted,The number divided 1.15 is the wheel hp.
Old Aug 29, 2018 | 11:15 PM
Z062FIT's Avatar
Valve springs
Who sells these for the fit?
Old Aug 30, 2018 | 10:45 PM
LRPTEC's Avatar
BC sells VALVE SPRING for the fit
Old Jan 31, 2019 | 08:40 AM
JingJangJoe's Avatar
How do i get 1?
Old Feb 3, 2019 | 09:00 AM
SFL_Fit's Avatar
I just cant see myself spending over 1,000 on an intake for the 1.8 that still wont make over 200hp.. I'm just gonna sit here and continue to save for my Kswap
Old Feb 3, 2019 | 08:25 PM
all you have to do is add a turbo charger. ;-)
Old Feb 3, 2019 | 08:33 PM
SFL_Fit's Avatar
not without swapping the internals. If you slap an ebay spooly boi on stock internals you'll send a piston into the atmosphere at 5psi
Old Feb 4, 2019 | 07:25 PM
USDM's Avatar
Wise choice.
Old Feb 21, 2019 | 11:13 AM
CarbonTek's Avatar
GREAT CHOICE!!! ...if you aren't racing in a class with a displacement cap.
Great choice... if you're in the land of cheap k-series engines and transmissions....or building a streetcar in a land where swaps are legal.
We are in neither. 1600cc displacement limit racing means that we are better off staying with this engine and finding ways to remove the bottlenecks that are built in.
Old Feb 22, 2019 | 02:09 AM
Myxalplyx's Avatar
Will you be able to make an intake manifold for the CVT/automatic transmission folks? The CVT will make much better use of the horsepower gains up at top. Especially if the engine tune could utilize the extra rpms and stay still at 7200-7500rpm. That would be ideal.
I would have been interested in sending your company a stock intake manifold to modify for CVT use, if I still had a Fit.
Old Jun 26, 2019 | 09:36 AM
elkaku's Avatar
How much will it cost...?😬😏😈
Old Jul 7, 2019 | 12:27 PM
Myxalplyx's Avatar
Originally Posted by elkaku
How much will it cost...?������
Go to their Facebook website HERE. They will provide you with more information there.
BTW: Check out their intake that they have also.
Redd
Jul 6, 2016 05:43 PM
ErinM
Apr 24, 2013 11:27 PM
gynosis
Jul 19, 2008 06:48 PM
tunerzimage
TunerzImage
Mar 19, 2008 07:05 PM
goodyonsen
Mar 11, 2008 05:35 PM
