3rd Gen GK Specific Fit Exterior Modifications & JDM Styling Sub-Forum Threads discussing exterior modifications and JDM styling for the 3rd Gen GK Honda Fit
Chinese LED Tail Lights?
Old Jul 15, 2020 | 09:47 PM
glasswave's Avatar
Anybody try something like this?
Car Styling Tail Lights Taillight case for Honda Fit taillights 2014-2018 Tail Lights LED Taillghts LED Rear Lamp
I need to replace a read tail light and wanted smoke ones. At less that $400, this would be cheaper than replacing the left unit and paying for tint film. OTOH, if they are crap or fail, then I am out $400.
I don't care so much about the fancy lighting effects, but mostly want smoked color. I'd also like decent reverse lights.
Anyone have experience with this sort of thing? Anyuone know of something similar here in the states from a reputable vendor?
Old Jul 16, 2020 | 06:57 AM
JingJangJoe's Avatar
Been using for 1.5 years. No problems so far. Mine's made in Taiwan
Old Jun 11, 2021 | 10:14 AM
kittenbutt's Avatar
Yeah. There is some rewiring necessary. Used this YT video:
Old Jun 11, 2021 | 07:53 PM
ReaperFit's Avatar
OMG YES! I bought those exact lights. They told me they would be plug n play for my 2020 Honda Fit...what a CROCK! I'm still waiting for them to send me some adaptors because I don't want to hardwire anything. Good Luck!
Old Jun 14, 2021 | 08:08 AM
Wht_GK5_Tx's Avatar
I have those
Youtube Demo
Check out my 1 other post. I have pics of these on my car. I have had them for 6 months or so and no issues. They have been through super heavy rain and the freeze that affected Texas so bad not too long too. No problems.
As fast as decent reverse lights, not so much here but, replacing the Lic Plate lights with the brightest led you can find is a good solution.
a note on installation, look up the YouTube video for it. It’s loads of Fun?
if you need more info just ask.
You can find these on Amazon.
Tail Lights installed.
Tail Lights in the box.
https://smile.amazon.com/dp/B08JGDJ2...ZNK1T39NYFAESW
Old Jun 14, 2021 | 06:55 PM
ReaperFit's Avatar
Problem is I have a 2020 & the plugs are completely different...can you link the install video? Thanks!
Old Jun 14, 2021 | 06:57 PM
kittenbutt's Avatar
Look above at my post. The two part video is what I used.
Old Jun 14, 2021 | 07:12 PM
ReaperFit's Avatar
I watched that video, but to much cutting for me. I think at this point I need to go to a pro to rewire all that.
Old Jun 14, 2021 | 07:34 PM
Wht_GK5_Tx's Avatar
It’s not that Bad.
I’m a half idiot and could do this. You need to buy a set of these
iJDMTOY (2) 7440 T20 Male Adapter...
Amazon Amazon
So you don’t have to fabricate a connector like he did and some of these
Kuject 120PCS Solder Seal Wire...
Amazon Amazon
So you don’t have to solder wires together, a drill bit to make the hole for the wire in the bottom, a heat gun to use with the 2nd item and lots of patience.
Old Jun 15, 2021 | 06:41 AM
ReaperFit's Avatar
I'm gonna try it...thank you for the links! I will post pics after im done.
Old Jun 15, 2021 | 07:15 AM
Wht_GK5_Tx's Avatar
Extra info.
the drill bit is to make a hole in the New Tail lights, NOT IN THE CAR. And 1 extra thing. The wire that comes out of the NEW pillar lights goes in the car through the hole where the old pillar reflectors’s guide pin went into, remove the plastic thing that guide pin goes into and run the wires through, along those wires is a rubber grommet that water proofs that hole. Careful with the grommet because it’s easy to pull on the wires too fast and pull the grommet through the hole, it’s a PÍA to get the grommet back in place. Do some research on how to use those heat solder things, a heat gun is better than a hair dryer.
Good luck and let me know how that goes. It’s going to look badass when you do it.
Old Jun 15, 2021 | 01:26 PM
ReaperFit's Avatar
LOL! everything you just said word for word happened to me when I was installing the pillar lights a week or so ago...I cut my nails really short so it took FOREVER! to get those tiny rubber pieces into place. I'm actually excited to use the soldering gun. I will definitely update when its all together. Hopefully this weekend : )
Old Jun 19, 2021 | 07:59 PM
ReaperFit's Avatar
DUDE! I did it!...Gonna post a video tomorrow! Thank you so much for your advice. Couldn't have done it without your links & the video that guy posted on Youtube. I hope I can return the favor someday
Old Jun 19, 2021 | 10:50 PM
Wht_GK5_Tx's Avatar
Awesome
Awesome news man. Now you can join the ranks of Fit owners that wear a DIY badge of honor for installing these tail lights on their own. Good Job man. 👍
marmaladedad
Jul 31, 2020 11:47 PM
smeister
Jul 8, 2015 06:21 PM
Fujiwara_toufu
Jul 24, 2013 12:51 PM
stryan
Aug 3, 2011 06:14 PM
Cat
Jul 1, 2011 06:15 AM
