3rd Gen GK Specific Fit Exterior Modifications & JDM Styling Sub-Forum Threads discussing exterior modifications and JDM styling for the 3rd Gen GK Honda Fit
Trailer Hitch Insert
Old Jan 15, 2015 | 01:12 PM
SilverEX15's Avatar
Now that I have my hitch installed, I'm wondering what kind of insert people are using to go from the hitch to the trailer. My trailer is currently frozen into the snow, so I can't do a direct measurement. From what I've seen, I can get straight, dropped down, or raised.
Old Jan 15, 2015 | 03:26 PM
CyclingFit's Avatar
Easy measurement, assuming our trailer is like mine and the tongue is on the same plane as the frame.... Just measure from the ground to the top of the frame rails. If you purchased the trailer from someone with web info, they may post the loading height.
Now measure to the hitch... The difference is how much rise or drop you need, assuming you want your trailer to ride level.
I think you know all this, I'm just giving a way for you to buy what you need and not have to go out in the drive, break it free from the snow, hold things up, etc....
My ball mount had to go UP, but that doesn't mean much based on so many trailer makers out there.
Enjoy,
Old Jan 15, 2015 | 03:58 PM
Bassguitarist1985's Avatar
Edit:
I have 15 ply tires on my trailer I got on order.
http://www.drawtite-hitches.com/prod...ll_Mount,36061
Old Jan 15, 2015 | 04:31 PM
CyclingFit's Avatar
Originally Posted by Bassguitarist1985
Edit:
Draw-Tite Class II Hitch Ball Mount 36061
You mean more like 15" wheel or tire outside diameter? and (multi) ply tires? Just curious and keeping things inline Most small trailer tires are going to be around 4 ply.
Casters | Wheels & Tires | Martin Wheel 480-12 LRB Trailer Tire 412B-I | B638425 - GlobalIndustrial.com
Old Jan 15, 2015 | 04:37 PM
15" wheel, sorry, I believe 6 ply. Though for a few more bucks I might just upgrade to 15" radial tires, 5 lug config. Its less than $100 bones more.
Old Jan 15, 2015 | 04:50 PM
SilverEX15's Avatar
Enjoy,
Thanks. That makes sense.
Old Jan 15, 2015 | 08:21 PM
dbhazz's Avatar
How did the hitch install go? Are you happy with it?
Old Feb 2, 2015 | 04:54 PM
SilverEX15's Avatar
It turned out fine. I just took my time. the only thing that shows is the receiver. I'll post some pictures - eventually.
Old Feb 4, 2015 | 10:10 PM
GotFitB13's Avatar
I've never installed a hitch, is it a bolt on for our cars? Or does that just depend on brand?
Old Feb 4, 2015 | 11:51 PM
The curt hitch was bolt on. No drilling or cutting. I think all the other brands that are available for the car are both on as well though some others may require more disassembly and reassembly than the Curt
Ky1eRC
Oct 27, 2020 08:46 AM
freak4afit
Aug 3, 2020 10:42 AM
hoopmatch
May 24, 2019 08:23 PM
Ex-MA Hole
Aug 12, 2014 08:42 PM
thewwkayaker
28
Jun 4, 2012 01:45 PM
