3rd Gen GK Specific Fit Exterior Modifications & JDM Styling Sub-Forum Threads discussing exterior modifications and JDM styling for the 3rd Gen GK Honda Fit
Curt Hitch or Hidden Hitch for 2015 Honda Fit LX?
Old Apr 26, 2016 | 11:47 PM
Namae Kana's Avatar
Both are about the same price.
Old Apr 26, 2016 | 11:49 PM
Bassguitarist1985's Avatar
Curt hitch bolts up. Hidden hitch requires removing and cutting a notch on the bumper cover. Hidden hitch sits about 2 inches higher than curt. All up to preference. Both work well for towing, bike racks, and other accessories.
Old Apr 26, 2016 | 11:59 PM
Namae Kana's Avatar
Oh! I just read the installation file CM_11406_INS.PDF for the Hidden Hitch on Honda 2015 Fit and it says 'no cutting'. Thanks for the pointer.
Old Apr 27, 2016 | 09:55 AM
My fault sorry. When I thought Hidden Hitch, I thought it was the Torklift Hitch. Two completely different products. This one yes you do have to notch out the bumper. The Hidden Hitch you do not.
Torklift Central | 2015 Honda Fit EcoHitch
Old Apr 27, 2016 | 02:40 PM
Namae Kana's Avatar
I watched the Torklift video. The video didn't show that you have to cut the bumper but it looks so tight I wonder.
It seems like the Torklift has the most ground clearance, followed by Hidden Hitch, with Curt the least. Is that correct?
Old Apr 27, 2016 | 03:34 PM
GeorgeL's Avatar
Obviously, if the receiver is high enough to require trimming of the plastic it will have more ground clearance. The rear of a Fit is fairly stubby so I don't think that ground clearance is an issue.
I'd love it if a manufacturer would make a hitch that came straight out of the rear bumper at the level of the body attach points. Put the receiver behind the plastic and you could make a flush cover for it. It would be stronger and there would be no clearance issue! Design it properly and it wouldn't even impair the rear bumper crush structure unless the receiver is attached.
Old Apr 27, 2016 | 04:34 PM
The Hidden Hitch and Curt should be exactly the same height. The Torklift yes is higher and comes in a 2" or 1-1/4" receiver.
I used a 4" riser. this is an old pic, but being in a riser configuration I put a backing plate in case the hitch gets knocked forward. I'll get an updated pic later at some point. Here is the pic from Etrailer.
Old Apr 27, 2016 | 11:03 PM
2015FITEX's Avatar
The hitch i put on said you had to bend the bracket for the exhaust which is 1/4" steel rod and basically impossible for me without removing the muffler from the car , what you are trying to do is get clearand for a bolt that sticks down and hits the top of the muffler. I took a hammer and put a dent in the top of the muffler...it worked "ok"
Old May 6, 2016 | 04:47 PM
Namae Kana's Avatar
Another option I'm considering is the Drawtite 24776 which seems easier to install than the Curt or Hidden Hitch products
Draw-Tite - Class I Trailer Hitch
Old May 7, 2016 | 09:14 AM
ron3's Avatar
Just installed a curt on my 2016 LX. Direct bolt up, no clearance issues. Very easy installation.
Old Mar 3, 2020 | 02:51 PM
Newfie's Avatar
Old Jul 2, 2020 | 09:51 AM
rla217@'s Avatar
Thanks for the tips, Jazu. Plan to install mine this weekend.
Old Jul 22, 2020 | 08:40 AM
knope's Avatar
This one looks neat as well. Bolts right up to the frame rails and tow bar. Draw tite - etrailer.com
Old Jan 10, 2022 | 08:26 PM
Mueller747's Avatar
Hello I have a 2019 Fit - when you say no clearance issues you mean no scraping on hills?
shamoo
SoCal Classifieds
Dec 18, 2014 01:48 PM
Ex-MA Hole
Aug 12, 2014 08:42 PM
thewwkayaker
28
Jun 4, 2012 01:45 PM
ricks
Jul 12, 2010 03:39 PM
hoss10
Feb 22, 2010 07:09 PM
