3rd Gen GK Specific Fit Interior Modifications Sub-Forum Threads discussing interior modifications for the 3rd generation GK Honda Fit
Sound Deadening
Old May 6, 2019 | 10:47 AM
azopelnut's Avatar
Sound Deadening
I love my 2015 Fit EX but I would like it if the cabin noise was a bit quieter. What materials has anyone had success with and what areas on the car have had the best results in dampening the noise?
Old May 6, 2019 | 09:21 PM
Action Jackson's Avatar
What did your search come up with?
Old May 7, 2019 | 07:50 PM
azopelnut's Avatar
No response
Old May 7, 2019 | 09:05 PM
fujisawa's Avatar
Searchy mcsearchface ("sound deadening")
I know plenty about this topic and will happily discuss if there are questions after reading some of the info out there. Plenty of people find the Fit's lack of grace disturbing.
Old May 9, 2019 | 12:03 PM
azopelnut's Avatar
Thanks for your offer. I was wondering specifically on the 3rd gen Fit like mine if there are critical areas that would have the greatest improvement in sound deadening. In other older cars I have owned I went the "el cheapo" route and used the off the shelf rolled material from Home Depot but I know that is not as effective as the material specifically made for sound deadening like Dynamat etc.
Old May 9, 2019 | 12:49 PM
fujisawa's Avatar
True, but there are non brand options like noico I used. There will definitely be some materials cost, especially if you use rubber sheeting anywhere. I have used noico and foam or fabric sound mats.
Personally I think under the dash and under the rear seat hinge is the most effective place to start.
Old May 9, 2019 | 02:02 PM
seditious3's Avatar
I have a '16 EX I got 2 months ago. It's quieter than I thought - my sister's '09 is very loud. In 2 weeks I'm doing a complete sound deadening/soundproofiing, and putting in an amp, speakers, and subwoofer. I'm stripping the entire car to the bare metal, using CLD (dynamat, but not that brand), a thin layer of closed-cell polyethethlyne foam, and then mass-loaded vinyl on top. Probably only CLD on the roof - evidently the headliner is a major pain in the ass to take down. The rest of the car is essentially a tinker toy.
Old May 9, 2019 | 03:48 PM
fujisawa's Avatar
How seditious is doing it is the proper way, in case anybody is wondering. Like many things, there is a best way and there are many less good ways available to get to the end state. It's a not-trivial amount of work to strip the interior, but I've done some pieces individually and I can conclude nothing about it is unachievable for a DIYer.
Old May 10, 2019 | 12:12 PM
seditious3's Avatar
I'm giving myself 2 full days, with help, to do it. I have all the proper tools. I think (hope) I should be fine.
Old May 10, 2019 | 07:23 PM
fujisawa's Avatar
I'm sure you'll be fine 😊 One guy here did it and his biggest complaint was he hadn't thought about where to put all the stuff he took out of the car
Old Oct 1, 2019 | 11:17 AM
glasswave's Avatar
I am doing much the same. Amp, 2 component speakers, door mounted sub then deadening. I was going to skip the headliner. I was told that unless you are getting lots of rain noise that the headliner does not help much. It has been suggested that I spray the fender wells from the outside with a spray on deadener.
A couple of questions, if I may.
  1. How thick is of closed cell foam (CCF) are you go to use to decouple the MLV? I have read 1/8" is sufficient, but those who sell a combined CCF and MLV tend to use 1/4 CCF bonded to 1/8" MLV (1 lb/ft).
  2. How do you plan to attach the CCF and MLV to the floor? The doors? Glue? Industrial Velcro tape?
  3. Are you using a CCF bonded to MLV product or are you putting them in separate?
  4. Are you doing full coverage CLD? Sound Deadening show down recommends just 25% coverage, Second skin reccommends 65% coverage.
  5. Do you know how hard spraying deadening coating to the fender wells would be to do?
Thanks.
Old Oct 1, 2019 | 11:46 AM
evilchargerfan's Avatar
Originally Posted by glasswave
  1. Do you know how hard spraying deadening coating to the fender wells would be to do?
may wanna spend a few mins, and read up on what Rick did
https://www.fitfreak.net/forums/3rd-...-campaign.html
take away = just make sure the foam is not the type that expands, ALOT. it can potentially do harm and/or misalign stuff
Old Oct 1, 2019 | 01:08 PM
glasswave's Avatar
Thanks,
If I do it, I'd be using a non expanding product like:
Second Skin Spectrum™ Spray On Deadener
My impulse is to just use CLD tiles, closed cell foam and mass loaded vinyl.
Old Oct 1, 2019 | 02:33 PM
that product looks promising.
Old Oct 1, 2019 | 10:32 PM
fujisawa's Avatar
Product says spray on
Comes in a tub
Old Oct 17, 2019 | 07:05 PM
glasswave's Avatar
Comes in a tub
You need to have a sprayer to apply it. Or it can be brushed on.
Here's an aerosol packaged product, if that is what you need.
Boom Mat Spray-on Sound Deadening Boom Mat Spray-on Sound Deadening
esnave09
Oct 7, 2017 11:41 PM
korgster
Nov 18, 2016 08:05 AM
pentium77
May 21, 2015 02:20 PM
nodelock
Oct 25, 2012 05:43 AM
toomuchjoy
Jun 10, 2012 09:31 AM
