Low Tire Pressure Message; not the ( ! ) symbol
Old Apr 20, 2019 | 04:50 PM
Battousai's Avatar
My less than a month old 2019 Fit Sport CVT just notified me that my tire pressure is low. No warning light ( ! ) on the dash but an envelope with ! icon on the entertainment console with a message that my tire.pressure was low. I checked the tire pressure on all tires and they were all fine at 34 or 36 I think but definitely not low.
I don't get why the car computer alerted me of that. Can't seem to remove the message as well as that envelope icon is still on the top center of the entertainment screen. Anyone have any idea what's happening here? Service Center is closed already.
Old Apr 20, 2019 | 04:56 PM
Brain Champagne's Avatar
I can't speak for the 2019s but with my 2016 it doesn't measure tire pressure per se but uses the ABS to see if one wheel is spinning faster than the others. Which would happen if it's low on air.
If you're sure the pressures are all okay then you can follow the procedure in the manual to reset the computer. In the 2016 there's a below-dash button on the left side to hold down until a light goes off.
Old Apr 20, 2019 | 04:58 PM
Battousai's Avatar
Thanks for the reply. I will take a look at that. And yes, the tire pressure of all four tires were good.
Old Apr 21, 2019 | 09:23 AM
QuiGonQuinn's Avatar
If you've checked all the pressures, then go into the settings on the guage cluster menu (the one controlled by the buttons on the bottom right of the steering wheel). there will be a TPMS section, and a "calibrate" option. Select calibrate, then drive like normal. It will take a little bit of time/miles before the message goes away, but it will go away on it's own
Old Apr 21, 2019 | 10:28 AM
wasserball's Avatar
His concern is that the low tire pressure amber colored icon did not showed up whereas, it was indicated in his display screen. The question is why not? Does the 2019 model changed the warning from the icon to screen display? I have a 2017 LX so low pressure warning is never on the display screen.
Old Apr 29, 2019 | 10:16 AM
Howie_Feltersnatch's Avatar
My 2018 EX throws the (!) symbol on the IP Display- I haven't ever seen that message come across the radio display before.
Old Apr 29, 2019 | 07:43 PM
Wow. So I was curious and downloaded the 2019 owner's manual.
It seems to imply there's a dashboard light for a flat, just like in previous years. But then later it implies that some vehicles have the info/reset as part of the radio.
So Battousai, let me ask this- when you first start the car does the flat tire light come on, on the dashboard? (in other words, is there even a light for that on the dash, or is it only on the radio?)
FYI the manual I downloaded is for the US and I do see that you're in Canada.
Old Apr 29, 2019 | 08:31 PM
Battousai's Avatar
Here is what my dash looks like when I start the car. I don't see any low tire light there. Last week, the Honda head technician or Foreman (I think?) said that Civics and Fits here in Canada don't have TPMS. They're still trying to figure out what the heck this is.
nicholasG
Mar 5, 2020 01:02 PM
Zardiw
Oct 9, 2019 09:04 AM
eggyacid
May 4, 2012 03:58 PM
qbmurderer13
Nov 20, 2008 12:03 AM
yeeman
Nov 22, 2007 07:24 PM
