OBD code 2422 2018 Honda Fit Evap Stuck
Old Jul 28, 2019 | 05:43 PM
KidSatanTx's Avatar
I got about 40k miles on my 2018 Honda Fit and the check engine light came on. I took it to Autozone and this code came up
OBD code 2422
Apparently that means the EVAP system solenoid is stuck. I need to know where it is located and how to fix. So far Ive been told it could be spider webs.
Old Jul 28, 2019 | 06:25 PM
Rooster's Avatar
take it to a dealer and see if they'll fix it free of charge. I see you're in Texas and the minimum warranty on emissions is 3 years, 36k miles for most components, however as a good will, maybe they would extend that coverage. I happen to live in one of the states where the warranties on the components is extend by time and or miles. Give it a shot, maybe you'll get lucky.
Old Jul 28, 2019 | 07:56 PM
KidSatanTx's Avatar
Code
I am in Texas but my car is registered in South Carolina, I already spoke with the dealer they want $374 to replace it. Autozone says the part costs $60 but Honda dealership says $180.
Old Jul 29, 2019 | 01:33 AM
wasserball's Avatar
Take a hammer and give it a tap, wack, or how ever you feel comfortable. It worked with one of my other cars.
Old Jul 29, 2019 | 04:44 PM
fujisawa's Avatar
Cause of stuck is usually carbon buildup. YouTube it. 12$ cleaner spray and you could be good to go.
Note the obd can ALSO know when the unit simply is not responding IE the component is dead. Probably separate codes. If so, then yes u have to replace it.
Accessing the 2nd gen is dead easy. Don't know what 3rd is like.
Old Jul 30, 2019 | 10:45 AM
payluder's Avatar
There is two evap solenoid one near the rear of the fill up and that one is called vent valve solenoid and then there is one at the engine bay called purge valve solenoid. I changed the purge valve myself but it require you completely remove the intake box to get to the nut holding the purge valve. I don't see how you can clean this part because the moving part is internal and you cant even clean unless you completely remove the valve.
Old Aug 3, 2019 | 04:30 PM
KidSatanTx's Avatar
Vent valve
It is the vent valve solenoid, where is located, how can I access it? Don't see anything on youtube.
Old Aug 3, 2019 | 04:45 PM
payluder's Avatar
it should be near the rear where the charcoal canister is. Here is a photo of the charcoal canister unit.
Old Sep 12, 2021 | 04:45 PM
Ompll06's Avatar
OBD code 2422
did you ever figure it out this just happened to me as well and i really cant find anything on it online
Old Sep 12, 2021 | 04:46 PM
Ompll06's Avatar
FITDragon
Nov 11, 2021 09:08 PM
Hondafit188
Jun 24, 2019 12:50 PM
Kevin Buonagurio
Aug 10, 2018 03:17 PM
drrusshorn
Feb 16, 2018 10:22 AM
