engine tick on cold engine
Old Oct 16, 2019 | 06:15 PM
monkeydave's Avatar
what you guys think of this noise, it isnt there first thing but comes in after a mile or so and then goes away when engine gets warmer
it appears to be comming from the number one cylinder exhaust valve cam lobe at the rear of the engine
it is strange to need a valve adjustment on a new car with 6000 miles on it
thanks in advance
Old Oct 17, 2019 | 09:37 AM
2Rismo2's Avatar
Seems like the normal injector sound to me
Old Oct 17, 2019 | 12:03 PM
monkeydave's Avatar
thanks for your reply, i dont think its the injectors as it isnt a rythmic sound, more of a clac noise that goes up and down with the revvs
Old Oct 20, 2019 | 09:34 AM
monkeydave's Avatar
deleted post
Old Oct 22, 2019 | 07:21 PM
monkeydave's Avatar
deleted post
Old Oct 23, 2019 | 01:33 AM
dwtaylorpdx's Avatar
Valve adjust due?
Old Oct 23, 2019 | 04:38 AM
monkeydave's Avatar
Originally Posted by dwtaylorpdx
Valve adjust due?
the car is one year old with 5500 miles on and just had its first service last month, i dont remember hearing the noise before the service but then the weather was warmer then too, serviced at main honda dealer with 0 20 mobil one fully synth
the noise is not there at first startup but comes in after a couple of mins and then goes away again after 5 mins or so, you only can hear it from outside so if you drive it more than 2 miles you would never hear it
i think one of the exhaust valves has slightly too much gap than the others from the factory or something like that, but if that was the case wouldnt it start tapping from startup
Old Oct 23, 2019 | 02:24 PM
Mister Coffee's Avatar
@monkeydave:
1) You should not need a valve adjustment at 5,500 mi. (But you know that.)
2) It's possible that, when the engine is cold, the oil is thicker and it muffles that noise. On the other hand, if the oil is cold, it's not circulating and lubricating optimally, and metal sounds should therefore be louder.
3) I never heard a Fit engine that didn't sound too noisy — like a diesel engine, almost. Other cars on the road also seem to louder than ever. It bugs me.
Sorry I couldn't be of any help here, Dave. Good luck.
Old Nov 24, 2019 | 02:28 PM
monkeydave's Avatar
deleted post
Old Nov 24, 2019 | 03:14 PM
woof's Avatar
Sounds like normal cold engine valve clatter. Why it's not there when you first start the engine I don't know. I make it a point not to listen to engine noises as much as possible because you'll just drive yourself crazy trying to figure them out.
Old Nov 24, 2019 | 06:53 PM
monkeydave's Avatar
thanks for replying, do you really think that sounds like normal cold cam lobe noise? im just worried as it is only comming from the rear of the number one cylinder exhaust valve cam lobe area and i dont want my cam lobe to be beaten to death as its only got 6000 miles on it
no one has messed with this car since factory, just had its first oil change at one year old but the weather is cold at the moment, thats probably why i didnt notice it in the warmer weather and it does go away after a few mins to sound perfect so like you say who knows, you are right about drivng yourself crazy listening to engine noises though lol
Old Nov 24, 2019 | 07:24 PM
woof's Avatar
Next time you go in to Honda for service ask the experts about it. I presume you're still under warrant for years to come so why worry about it.
Old Nov 24, 2019 | 07:29 PM
monkeydave's Avatar
thanks for replying, i will ask the next chance i get with honda and yes i got a couple of years left on warranty
they will probably tell me what you told me lol
cheers
Old Nov 26, 2019 | 05:01 PM
evilchargerfan's Avatar
so many deleted posts
how will I ever learn about the episode that is MonkeyDave's engine tick on cold engine
Old Nov 27, 2019 | 01:16 PM
monkeydave's Avatar
sorry they were just old videos that weren't very clear so i replaced with the one that is there now
willy65000
May 25, 2017 06:57 AM
rigas520
Jul 14, 2015 03:09 PM
cjecpa
Apr 14, 2013 04:52 PM
MMurray
Oct 8, 2010 03:49 PM
Spooling
Jul 21, 2009 10:54 PM
