Does the Mirror position adjustment switch light up ?
Old Mar 7, 2020 | 03:17 PM
Ilja Lichy's Avatar
Hi guys I drive a Honda Fit 2015 LX
Here’s a question if you drive the same vehicle.
Is the mirror position adjustment switch backlit? Aka does the mirror position adjustment switch light up when you turn on the headlights ?
Please let me know I’m just wondering if it doesn’t or if my light bulb is burnt out.
Thanks.
Old Mar 7, 2020 | 04:29 PM
Fuelish's Avatar
2015 LX here as well....iirc, no it doesn't light up...or mine's not working either Guess Honda figures you don't use it often enough to bother with backlight? Who knows?
Old Mar 7, 2020 | 10:26 PM
Ilja Lichy's Avatar
what about your fan speed control button ? Are the 1,2,3,4 numbers backlit?
Old Mar 7, 2020 | 11:34 PM
woof's Avatar
The more back lighting you want the more wiring you have to run through the car and the more chances of things breaking - wiring pulling loose from a terminal, wire breaking, terminal corroding. Making a car more complex makes it less reliable and needing more repairs, as minor as those repairs might be. Putting a sensor in the washer fluid jug might be handy for measuring the fluid level but when the owner uses a washer fluid which destroys the sensor and results in a $100 repair then perhaps not putting that sensor in for both the manufacturer and car owner would have been a better idea.
I've found that if you have a car long enough then you know exactly where the switches are that you commonly use and you can close your eyes and still reach out and accurately touch them. You don't need to read anything.
Old Mar 8, 2020 | 06:25 PM
2bFit's Avatar
that just cheapness from Honda, the backlighting is already there for the window and door lock switches; it can be that much to add the mirror control.
Old Mar 9, 2020 | 07:37 PM
Jazu's Avatar
No - it certainly doesn't on my cheapo LX - some days I dream of manual crank windows and their simplicity relative to the extremely slow powah windows that my LX is graced....
Old Mar 10, 2020 | 01:04 AM
2bFit's Avatar
@Jazu I agree. I could do without the power window (with manual, you don’t have to worry about bad motor and rain before you can get replacement) but the power mirror is nice though.
Old Mar 11, 2020 | 03:42 PM
Fuelish's Avatar
Am pretty sure the fan speed #s are backlit, shall check next time I'm in the car
boyito
May 25, 2012 03:20 AM
ElanS2
Aug 13, 2009 12:29 PM
ElanS2
Aug 13, 2009 11:26 AM
alexfree05
Mar 25, 2008 01:34 AM
