3 dash lights after rear soacer install
Old Jan 1, 2021 | 06:05 PM
cqker's Avatar
i just installed 25mm rear spacers, and about 2 minutes into my test drive, the TPMS, Traction control, and power steering(?) lights went on. also on thge right gauge it's saying to "check charge system".
this all seems odd to me that rear spacers would cause this. is this just the computer getting confused about the car's alignment or something? anyone else have similar issues after installing spacers?
Old Jan 2, 2021 | 08:36 PM
2015FITEX's Avatar
weird.....battery terminals tight?...cant see how JUST doing that would trigger anything
Old Jan 2, 2021 | 08:59 PM
cqker's Avatar
yes, very weird. idk if it’s just a coincidence that this problem just so happened to occur right after the install or if it’s the spacers fault. battery terminals are good, i tried unplugging the battery for a few min to see if it would reset the lights with no luck.
Old Jan 2, 2021 | 10:02 PM
2015FITEX's Avatar
maybe you had the doors open and the battery is low.....what is battery voltage ?
running and not running
Henry Cruz
Mar 9, 2019 08:49 AM
liverpoolfcfan
34
Sep 30, 2013 11:14 PM
melv0
May 20, 2012 11:56 AM
prossett
Mar 14, 2008 01:29 PM
heymikesays
Oct 25, 2006 09:50 AM
