2015 light issues
Old Jul 28, 2022 | 07:17 AM
Strlitbrite's Avatar
2015 light issues
2015 Honda Fit. Right side headlight, high beam and blinkers are out. Have changed right headlight, fuses from fuse box in car and in hood. Still not working. Left side is fine. What else could it be? Also my check charge system alert is on on my dashboard. So frustrating.
Old Jul 28, 2022 | 07:34 AM
bargainguy's Avatar
Welcome. I'm assuming your Fit has not been in any kind of crash which could damage the electrical system, and that the system is intact and whole (not a rebuilder/salvage etc.).
If the fuses and headlight bulb check out OK but the directional is out on one side, the problem is most likely with the headlight switch. Don't know if you're doing the work yourself or at a dealer/independent, but that's where I'd start.
Old Jul 28, 2022 | 08:59 AM
Thanks, I will start there. We are doing it ourselves if we can. I appreciate it.
thanks I appreciate it. We are doing it ourselves if we can. I will start there
Fit Pal
Mar 14, 2016 04:00 PM
jodfie
Dec 26, 2014 01:46 AM
eCity Fit
Oct 5, 2014 05:05 PM
