Engine noises, looking for help
Old Apr 28, 2023 | 06:47 PM
canuk's Avatar
Hi all and sorry for the long explanation, just hoping to provide as much info as possible
​​​A few weeks ago my 2015 with 235000 kms started making a slight squeal from the passenger side of the engine while I was driving. After it started getting worse I decided to take a closer look, but I was only able to replicate this squeal while driving. Idling would not replicate the sound. A cursory inspection showed a quite cracked and worn serpentine belt.
I changed the belt a couple days ago, but the squeal did not go away. Rather, a sound very similar to the VTC actuator startup issue began as well. However, unlike all of the posts I have read about the VTC actuator grinding issue, the noise does not go away after start up. Rather, it seems to come and go regardless of how I drive or engine temperature, and exclusively at low RPMs.
The sound could be best described as a diesel engine. However, when I accelerate the noise goes away.
My thought is that the two sounds are unrelated and just coincidental, and I am hoping the squeal might just be a tension pulley issue, which I intend to verify this weekend.
But the grinding noise has me concerned. There are some excellent YouTube walkthroughs on changing out the VTC actuator, and I would prefer to do this myself. However, my question is, is it possible that this is in fact the issue given that the noise persists after warm up?
flyingby
Mar 5, 2025 10:45 PM
canuk
Apr 30, 2023 05:19 PM
mnapuran
Jun 11, 2016 06:00 PM
blazej
Feb 24, 2016 07:37 PM
3cg
Mar 24, 2015 06:35 AM
