Replaced Driver's mirror, now no HVAC fan, AC or mirror adjustment...
Old Sep 8, 2023 | 08:19 PM
glasswave's Avatar
Question Replaced Driver's mirror, now no HVAC fan, AC or mirror adjustment...
Hello,
I just had my driver's side (left) mirror replaced, now the HVAC fan, AC or mirror adjustment no longer work. Body shop says they have checked the fuses. Any ideas? All those things worked when I brought her in.
Any ideas?
Old Sep 11, 2023 | 10:30 AM
FitAnotherWay's Avatar
Maybe when they were replacing things they didn't connect one of the wiring harnesses or left it loose. You could go around the mirror area and reconnect everything and make sure it's securely connected. I try to avoid visiting a mechanic if possible. Last time I was at the dealer they didn't attach the break calipers to the car.
Old Sep 12, 2023 | 12:20 PM
glasswave's Avatar
Thanks for the reply.
I am thinking that may be the case.
I forgot to add that the first time I tried to roll the window down, it got stuck at about 2/3 down. Then it worked fine. I am guessing some wires were left in the window path and when I rolled down the window, the wires were unplugged.
Old Sep 14, 2023 | 02:36 PM
glasswave's Avatar
No luck on taking the door pannel off to look for loose connections. The body shop is washing there hands of it.
yuffers
Aug 10, 2014 03:51 PM
Amanda Tabary
Feb 22, 2014 02:48 AM
BraytonAK
May 27, 2010 03:27 AM
pwnstar
Mar 9, 2010 03:42 PM
einhan
Sep 26, 2006 10:36 AM
