Is car considered level on 4 jack stands - Transmission fluid check
Old Sep 26, 2023 | 09:43 PM
Kirkland's Avatar
Is the car considered level if its up on the pinch welds with 4 jacks on a level surface? Trying to make sure that the car is level when checking the transmission fluid.
Old Sep 27, 2023 | 07:02 AM
Drew21's Avatar
That's pretty much the definition of level. Note how many times "level" appears or is implied in your description of the car.
Level floor + (presumably) level jack(stands?) + equivalent (i.e., level) position on the car = level.
I'm not sure how you can do it any better.
Old Sep 28, 2023 | 06:44 AM
2Rismo2's Avatar
It would depend if the ground the jack stands are on are level...
Old Sep 30, 2023 | 05:28 AM
fibrepunk's Avatar
I remember I used a laser level w/ self leveling against the side/bottom of the Fit with 4 jack stands to check for level to do the transmission fluid drain/fill.
Old Sep 30, 2023 | 09:46 AM
Drew21's Avatar
Sometimes good enough is good enough. You're not trying to land a payload on Mars, you're trying to get a car roughly level. If it looks level to your eyes, it's fine. If you drain 2% more or 2% less of the old fluid than if the car was perfectly level, you're still fine. The important part is doing the fluid change somewhere near the recommended time/mileage.
If you reach the point in life where you're using a laser level on your car, you're probably better off taking it to a dealership and paying for them to do your maintenance. On their lift, which I'm certain is Honda-certified as perfectly level...
Old Sep 30, 2023 | 10:00 AM
mykizism's Avatar
Raybisono
Apr 26, 2023 03:24 PM
Guillaume St-Cyr
May 13, 2022 08:52 AM
GAMiniMiniVan
May 15, 2021 06:11 AM
JerryHughes
Jul 13, 2019 11:09 AM
rayray38
Jun 24, 2015 10:24 AM
