2005 Jazz Tranmission fluid level
Old Jun 24, 2015 | 10:24 AM
rayray38's Avatar
Hi. I am a new member.
Would you guys tell me the correct procedure of checking the tranmission fluid level?
I just changed the fluid of my Jazz.
I find the fluid level is higher than the max 'HOT' point 1cm before starting engine(My car is Off for overnight). After starting the engine, the level goes down at a point between 'COLD' and 'HOT'. The level is higher than max 'HOT' point around 2-3mm after i drive for a while.
Is there any wrong with my fluid volume? Do I need to drain out some?
JerryHughes
Jul 13, 2019 11:09 AM
JerryHughes
Apr 10, 2019 11:33 AM
domromer
Feb 19, 2019 06:37 PM
kaede1337
Jul 31, 2016 05:22 PM
Kofi Anim-Appiah
Aug 6, 2005 04:43 PM
