Dead USB Ports
Old Oct 15, 2023 | 09:30 AM
SilverEX15's Avatar
Dead USB Ports
I have tiny SanDisk flash drives in the two USB ports. Both ports are now dead. Am I the first to have this happen. Pushing the button to switch inputs does not give me the option of USB.
Old Oct 16, 2023 | 08:37 AM
SilverEX15's Avatar
The port in the armrest came back to life yesterday.
Old Oct 16, 2023 | 12:16 PM
FitAnotherWay's Avatar
Perhaps a loose connection on the back of the head unit?
Old Oct 16, 2023 | 12:26 PM
SilverEX15's Avatar
I looked, and everything is connected - all original factory wiring. At least one of them is working now, so that's something.
Old Oct 16, 2023 | 02:47 PM
Drew21's Avatar
Have you checked the USB drives in another device or tried different USB drives in your car? They don't last forever, and the sorts of vibrations and cold/heat cycles in an automobile application might increase the rate or likelihood of failure.
I have a SanDisk USB drive that we use in our multimedia setup at home which has partially failed in the past month or two. I say "partially" because it still seems to read correctly from files already on the drive but the write performance has fallen to a level that makes the drive basically unusable. Copying a 1 GB movie onto the drive from my computer takes well over an hour and the drive gets scalding hot in the process.
Old Oct 16, 2023 | 03:26 PM
SilverEX15's Avatar
Thanks. Maybe it just "expired." Nothing lasts forever.
Old Oct 16, 2023 | 07:06 PM
Action Jackson's Avatar
Depends on how often new info is written to the drive. Occasionally I would need to reformat the drive and re-copy everything.
Old Oct 17, 2023 | 07:55 AM
SilverEX15's Avatar
No writing - all reading.
Old Oct 30, 2023 | 09:39 AM
bill bosco's Avatar
mine never worked , i can't charge my phone with them
Old Oct 30, 2023 | 09:40 AM
SilverEX15's Avatar
Mine are both working now. Odd.
Old Oct 30, 2023 | 09:41 AM
SilverEX15's Avatar
SilverEX15
Mar 29, 2016 11:23 AM
Bassguitarist1985
15
Sep 10, 2014 05:51 PM
Carmen Sandiego
Apr 4, 2013 01:21 PM
OliviaNewtonJohn
Jul 11, 2012 08:05 PM
sofosal
Jan 15, 2010 11:19 AM
