"Brake!
Old Oct 24, 2023 | 10:06 AM
SilverEX15's Avatar
"Brake!
I know two people who have 2020 Fits - EX. Occasionally, they get a lit-up warning, "BRAKE," along with an aural warning. What's going on? They can't see any reason for that to happen.
Old Oct 24, 2023 | 10:49 AM
woof's Avatar
One possibility: If the brake pads are a bit worn that can draw fluid from the master cylinder to the wheel cylinders. That will leave the master cylinder a bit low on fluid which can trigger the brake light. Initially this is usually more noticeable when taking corners which will cause slightly low brake fluid to slosh around a bit and trigger a warning light. The solution is to top up the master cylinder a little bit.
Old Oct 24, 2023 | 11:29 AM
SilverEX15's Avatar
I found it - Page 273 in the manual. It's a safety feature.
Durockrolly
May 17, 2021 12:31 AM
Dorna
Apr 26, 2021 09:18 PM
dirkpitt73
Jul 9, 2020 05:58 PM
RavenManiac
May 29, 2020 01:08 PM
BrokenLimits
Jan 29, 2020 09:01 AM
