Battery won't charge, weird woodpecker noises coming from fuse box and power relay
Old Nov 22, 2023 | 01:27 AM
amyvegan's Avatar
Hi.
I have a 2015 fit. About 60k miles and battery is from 2020.
It appears one of the cabin interior lights was left on for about 48 hours.
Car wouldn't start. Cabin light barely illuminated.
Car would NOT charge with a portable car charger or jumper cables and another car.
Very woodpecker/repetitive clicking noises coming from fuse box and power delay.
Please give me advice before I tow the car to Honda.
I'm "freaking" out.
Thank you.
Old Nov 22, 2023 | 01:57 AM
Chitown Fit's Avatar
Push Button Start?
Did you replace your push start button?
There's a recall issue with push start buttons on 3rd gen Fits. This is a free no charge replacement at Honda.
Old Nov 22, 2023 | 08:56 AM
woof's Avatar
Battery's gone.
Old Nov 22, 2023 | 10:29 AM
amyvegan's Avatar
yes under warranty previously.
thanks.
Old Nov 22, 2023 | 10:30 AM
amyvegan's Avatar
i guess that's good news.
the clicking noises are strange.
my previous honda was silent when the battery was gone.
what causes those clicking noises?
thanks.
Old Nov 22, 2023 | 11:43 AM
woof's Avatar
The battery voltage is too low. The mechanical relays try to connect but the voltage is too low to hold them and so they disconnect but then they connect again ...and disconnect, over and over again. The relay arms are bouncing back and forth unable to hold a connection because the battery is too weak and thus the clicking sound they produce as they repetitively make and break contact. If the battery voltage goes lower then the relays won't even make the effort and the noise will be gone.
Old Nov 22, 2023 | 05:59 PM
New Battery.
Get a Diehard Battery from Advance Auto.
Old Nov 22, 2023 | 08:06 PM
2015FITEX's Avatar
i think the battery voltage is too low....this is going to sound crazy but disconnect battery and let it sit 24 hrs, (voltage should rise a tiny bit) THEN try and charge it with a wall pluggable charger
Old Nov 22, 2023 | 10:59 PM
amyvegan's Avatar
perfect explanation. thank you. i had a 1998 civic until 2015 and don't recall this noise at all.
i did get AAA to come and they tested the battery, said it's fine....they fully charged it and noise is gone.
thanks.
Old Nov 22, 2023 | 11:08 PM
2015FITEX's Avatar
1999 civic hatchback till 2015.....they don't make em like they use too !...lol...200,00 kms on it...water pump leak...had enough .got the fit because of the increased HP with the direct injection...my bad!!!---roll eyes
Woof called it also
so long as your "up and running" all good!!
Old Nov 23, 2023 | 08:59 AM
woof's Avatar
Worth keeping in mind for someday if you have to replace the battery to make sure you put in the larger 51R battery instead of the Honda OEM small 151R battery. The large 51R adds a lot of capacity which might avoid situations like this. It's a tight fit but it does go in.
Craig Cole
May 23, 2025 10:55 PM
catbird
Sep 28, 2023 04:01 PM
ScottE03
Jun 9, 2020 10:54 AM
Rfitfit
Dec 14, 2015 10:20 PM
pearl
Dec 4, 2014 06:42 PM
