2015 Honda Fit Ex Just Purchased
Old Jan 24, 2024 | 05:02 PM
Hondafit61's Avatar
Hi Folks,
I just traded in my 2011 Toyota Prius for a 2015 Honda Fit Ex. It has 68k miles on it and is in really nice shape. As a side note, I am now retired, and if i put 3k miles in a year on a car, that would be a lot. Anyway, the used sales lot did a 63 point inspection and replaced the oil, tires and did an alignment. I was wondering what other maintenance I should do. I tried looking at the past records, but it seems they rarely used Honda dealership, so I can't really find many past records of maintenance. Should I have the transmission oil changed? According to the maintenance records I found Honda recommends at 60k? I asked a local shop if they could do it, and they asked if it was a CVT Transmission. I replied yes. They said they won't touch it. I asked why and they said too many things could go wrong. Any advice on what to do?
Thanks!
Old Jan 24, 2024 | 09:47 PM
woof's Avatar
If they haven't been changed since the car was built, change the CVT fluid, change the radiator fluid, change the brake fluid. I changed my own CVT fluid last summer and it was relatively easy but time consuming. I would recommend going to Honda for the CVT to make sure the right fluid is used.
Old Jan 29, 2024 | 05:47 PM
Hondafit61's Avatar
Thank you for the reply. Do these fees sound reasonable:
1) CVT Transmission Fluid would be approx $140 + tax
2) Brake Fluid Change would be $139.95 + tax
3) Coolant Service would be approx $110 - $120 (+tax) depending on coolant capacity.
Thanks!!
Old Jan 29, 2024 | 08:38 PM
woof's Avatar
Last summer my CVT fluid was C$124 (about US$90) for 4 liters (which is about 4 US quarts.). The fill is actually only about 3 1/2 quarts. Anyway your $140 is kinda high unless they're selling you more than 4 quarts.
Brake fluid can't remember what I paid at Honda but that looks reasonable. Mostly labor cost.
Coolant. Mine was done under warranty because of a leak so it didn't cost me anything. (The coolant leak was actually my fault and I should have paid but I didn't figure that out until later)
Old Feb 2, 2024 | 04:31 PM
fibrepunk's Avatar
68k miles? I recall my front brake pads needing replacement around 75k miles, so also check that if it hasn't been replaced before.
Old Feb 19, 2024 | 09:33 PM
DaBinChe's Avatar
at 68k miles yes cvt oil, then every 30k after that. Brake fluid every 3years. Honda type2 coolant is every 5years/60,000miles...but there is other more modern coolant that can last longer 10years/150k miles, just make sure all the old is flushed out first before changing coolant type but always stick to Ethylene Glycol type. I just recently flushed out my 2015 w/87k miles, first time ever and it wasn't so bad, changed to a longer life coolant but flushed out the old first. Look up my username on youtube and playlist for the FIT. As for the brakes, just shine a flashlight on the pad to see how thick they are, if down to 5mm they'll need changing soon, the inside will wear out faster than outside by a few mm
Ogrelode
Jan 18, 2019 11:05 PM
15FIT-EX-4SALE
Oct 19, 2018 01:31 PM
zenmasterfit15
Jun 8, 2018 10:34 AM
David Lawrence
Feb 13, 2017 07:19 AM
Heitor Terças
Apr 27, 2016 11:04 PM
