Engine Idle Rattle - Anyone Have This?
Old Apr 14, 2024 | 03:09 PM
fitfit2015's Avatar
Question Engine Idle Rattle - Anyone Have This?
90k miles. Only other issues are a busted AC and the common VTC rattle, which sounds a little different perhaps. Not sure if they're related, gut says so.
This sounds a bit like a horse galloping. It goes at about 400+ RPM, so about half what the engine as a whole is doing. It is irregular in its beats, and there is a mixture of more clopping beats and metallic slappy beats, with the latter less common. Hard to pinpoint, but it seems loudest nearest the center of the top engine.
I replaced the chain tensioner, but it made no difference.
Video attached.
File Type: mov
Old Apr 15, 2024 | 09:52 PM
2015FITEX's Avatar
i valve grossly out of adjustment ? or 2?...half RPM...id check valve adjustment...CHEAP check...my valves rattle on cold starts now ...does go way....does it go away ???....id say no.....OR piston slap?....probably engine DONE on that one,but it should go away when hot
Old Apr 16, 2024 | 12:21 AM
Chitown Fit's Avatar
Engine Noise.
With 90,000 miles you should have had at least one valve adjustment done.
Go to your local Honda Dealer and get a valve adjustment right now!!!!!!!
Don't wait!!!!!!!!
Old Apr 16, 2024 | 12:40 AM
2015FITEX's Avatar
yea...60,000 KMs and i shouldn't wait either....ugh, unbolting the plastic valve covers....will I???
Old Apr 16, 2024 | 12:34 PM
fitfit2015's Avatar
I'll be taking it in for an adjustment and general look-over, thank you everyone. I'll report back afterward.
Old Apr 17, 2024 | 09:03 PM
fitfit2015's Avatar
Got it back: that was not the issue. But it does run a bit smoother. But it's still clanking.
Take it to someone else to diagnose I guess.
Old Apr 18, 2024 | 08:23 PM
2015FITEX's Avatar
Groan....i sense you didn't go to the dealer.
i would have got a horrifically overpriced valve adjustment and mentioned the clanking....but i sense we are past that.
i would go to dealer and pay horrifically overpriced diagnosis fee.
does it clank all the time, consistently, no matter what load or temperature the engine experiences? ????
after listening to the video 100times id say the exhaust piping is loose.
put your hand behind or ideally under car, does any piping or bolts or HEAT SHIELDS feel loose ?
when you first start cold car, does your hand feel any exhaust leaks ?
i thing an exhaust coupler is loose and thats the clanking...OR a head shield
Old Apr 20, 2024 | 12:40 AM
2015FITEX's Avatar
Old Sep 19, 2024 | 03:31 PM
fitfit2015's Avatar
Eventually it was diagnosed as a bad AC compressor. Also the AC doesn't work. Makes sense.
Old Sep 19, 2024 | 07:28 PM
2015FITEX's Avatar
Huh,,,,,good to know, thanks
jmforem
Jul 18, 2023 11:06 AM
PhaseShiftDown
Oct 19, 2014 03:33 PM
Bi(l)ljud
Sep 15, 2013 06:26 AM
tdj
Jul 21, 2009 09:58 PM
BBGorson
Oct 24, 2006 10:17 AM
