Engine cover/splash shield came off (finally)
Old Apr 29, 2024 | 08:14 AM
futhamucka's Avatar
The plastic cover/shield that needs to be removed to change the oil on my 2017 Fit finally came off, as they notoriously do, the other day. As expected the stupid plastic "bolts" at the back were nowhere to be seen, but the screws mostly held on and it didn't scrape on the road and destroy itself. Since the cover is undamaged I intend to put it back but I have a couple of questions:
  1. What's the best way to secure the back two holes? I could just get some replacement plastic bolts (Part #: 91514-tg1-t01), but there has to be a better way!
  2. I'm missing a couple of screws that must have rattled loose when the plastic bolts gave up. I can't find the part number for those. The ones that I have are not rusty so I'd like to get proper replacements.
Old Apr 29, 2024 | 10:11 AM
woof's Avatar
1. The plastic push pins are the only way to hold the cover on other than maybe with long ty-raps which you would have to cut off every time you want to remove the cover. The thing with those push pins is that they are not really intended for re-use. I just changed my oil and I installed new push pins as I do every time. They hold perfectly for me and have never failed.
2. Go to your local Honda parts department and get them to look up the part number for the screws. They should have them in stock. Buy extra.
Old Apr 29, 2024 | 10:53 PM
Chitown Fit's Avatar
Plastic Engine Cover.
Mine was scraping speed bumps and snow.
One winter day at the gas station my totally fell off. I picked it up and put it inside my Fit. When i got home I tossed it in the backyard. And eventually threw it in the trash.
Old Apr 30, 2024 | 08:12 AM
futhamucka's Avatar
Sigh. I was hoping there was a better way since it's been an issue for so long.
I actually had one of the plastic pins spare left over from when one fell off/broke many years ago. I'll stop at the dealer on the way home and get some replacements.
Old Apr 30, 2024 | 09:30 AM
FitAnotherWay's Avatar
If you want to do better than the OEM pins you could install some rivnuts.
edit: Jack nuts if you want to skip the fancy tools.
Old Apr 30, 2024 | 09:53 AM
futhamucka's Avatar
I've never seen jack nuts before. Those look like they would work very well.
Old Apr 30, 2024 | 10:06 AM
woof's Avatar
You can buy a large bag of these things fairly cheaply on Amazon. That's what I did.
Old Apr 30, 2024 | 10:10 AM
futhamucka's Avatar
Do you have a link? I searched for the part number and found some generic round pins, but I don't know if they'd work.
Old Apr 30, 2024 | 10:53 AM
woof's Avatar
Search for "push pins automotive 10 mm" on Amazon. You need to look at the pictures and find something which looks very similar to the Honda one and is rated to fit into a 10 mm hole - that's the size of the hole in the under cover. In various sizes these things are widely used on almost all cars made today.
For example here's one:
Honda 10 mm push pin Honda 10 mm push pin
Old Apr 30, 2024 | 10:56 AM
futhamucka's Avatar
Excellent. That's great information. I think I actually have a variety pack of similar things. I'm going to have to check to see if I have any in that size.
Old May 1, 2024 | 10:56 AM
lausy's Avatar
I went to a local dealer couple months back trying to get some of those replacement screws (the ones up front). They quoted me almost $10 each. Needless to say, I quickly ran out of there.
Old May 1, 2024 | 11:07 AM
futhamucka's Avatar
Hah, that was my experience last night.
The screws were over $8 a piece (I only need two) and the plastic pins were over $5. I asked if the screws were made of solid gold, and then politely left. They seemed very understanding.
When I got home I found that I did indeed have some pins that will work, and probable hold better than the OEM ones. The screws were a little more tricky. I looked around a local Ace Hardware, but they didn't have anything that had a wide head like that. So grudgingly I ordered some on Amazon. $6 for a pack of ten is a bit more reasonable.
Old May 3, 2024 | 09:18 PM
2015FITEX's Avatar
i need the wide head screws and will happily pay 6 dollars if i dont need to talk to a living soul.....whats the part number?
i used "well nuts" i got at home depot for rears when they blew off through giant puddle..i think its better to allow "blowage" if needed...as you have done.....I usally "Hinge" the cover on the rear when i change the oil so i wanted something "better" ie (pay allota money feel better)
Old May 5, 2024 | 07:21 PM
futhamucka's Avatar
The 10mm automotive push pins fit perfectly in the two rear holes and they hold much firmer than the original ones.
I used
these these
for screws. Turns out they're just #10 screws with a washer painted black. They fit perfectly. Five minutes later everything is attached again.
Old May 5, 2024 | 10:13 PM
2015FITEX's Avatar
thanks,unfortunately in canada its 6 dollars and 9 dollars shipping...lol...i cant pay that ...the #10 is good info,might go to homedepot and look around. maybe i can just use a regular washer under a reg head screw
Old May 5, 2024 | 11:23 PM
woof's Avatar
I bought a bag of machine screws for the Fit with the built in washer from Amazon Canada a few years ago in case I had to replace the existing ones (due to rust) but I set it aside and I never actually got around to checking them out to make sure they were the right size. An ordinary sheet metal machine screw of the right size/thread pitch should do and all you have to do is throw on a washer. Maybe next oil change when I'm under there I'll test them out. I had marked on the bag " #6-16 " as the size at the time I received them but again not sure if that's correct.
Old May 10, 2024 | 06:24 PM
fibrepunk's Avatar
Somehow those who did their own oil change, cvt transmission fluid change etc, never had issue with the loose screws/push pins/splash shield. Seem like those who have their car serviced by others are the ones with issue on the splash shield/loose screws/push pins.
Old May 10, 2024 | 08:26 PM
2015FITEX's Avatar
i think thats generally true, i never EVER removed the rear ones....until giant puddle blew one off......those back ones arent great though...DO better honda!!!...LOL
Old Oct 29, 2024 | 12:21 AM
Inafranticfit's Avatar
My suggestion
Buy the clips from Amazon, https://a.co/d/2Q3QqhH
If it hasn't been said yet, Clip the end of the push pin to allow it to stay fastened when pushed in, but also easily removable when doing your next oil change. See image below, push pin on the left is clipped
Old Oct 29, 2024 | 09:32 AM
bill bosco's Avatar
i'll have to check that out . i've lost one about a year and a half ago , so i now stock some extras from Honda just in case it happens again .
when ever i change the oil i check that the retaining screws are all in good shape . the splash shield is a pain , but i like that it helps keep
the engine compartment pretty clean ( as compared to no shield at all ) . it's a 19 , and i've lucked out with no real heavy snow so far since it was
new . always wondered how it would hold up
