Fuel injector replacement
Old Aug 13, 2024 | 12:54 AM
Jaustin73a's Avatar
My wife’s 2019 fit is at 106k and needs new injectors.
spent $1300 today to order a set from Oreillys (mainly due to lifetime warranty.)
my question is should I also replace the fuel rail and fuel joint pipe as well?
The manual I’m looking at says replace fuel joint pipe but doesn’t mention fuel rail so I thought I’d seek some advice from others.
I appreciate any help!
Old Aug 13, 2024 | 11:44 AM
Hootie's Avatar
No need to replace the fuel rail. The fuel joint pipe is highly encouraged because it essentially seals the fuel lines in a similar manner that the aluminum crush washers do to our drain plugs. So by Honda's procedures, they fall into the "one time use" category.
Make sure to lube the o-rings and teflon seals on the injectors well before insertion.
Also, it would be a great time to do a valve adjustment and walnut blast the intake valves while everything is apart.
Old Aug 13, 2024 | 11:48 AM
Jaustin73a's Avatar
That’s what the research I’ve been doing is saying. Thanks. And already had the blasting done at dealer before they told me it was injectors.
Slick Seal
May 9, 2023 04:03 PM
VelvetB
Nov 3, 2018 11:59 PM
Vash
Feb 2, 2018 08:34 PM
azkikersfit
Sep 29, 2007 12:35 AM
NCFit
Jun 15, 2006 04:45 PM
