2016 Honda Fit Starting Problem: Not the battery
Old Feb 23, 2025 | 03:01 PM
AKByrde's Avatar
Hi All,
This is my first post here. Glad I found this forum.
This morning I helped a friend replace the battery on a 2016 Honda Fit. The car has not been running since late Fall 2024; I was told it just wouldn't start after a light was left on. Before replacing the battery, I attempted to jump the car and left it on a 2 amp charge for ~24 hours, but no luck. The car still won't start post battery change. No click, no lights. I did clean off the leads with a battery terminal brush. There was some corrosion, more on the positive lead. It's a push button start, and the car is in Park. It's like the electrical circuit is not complete. The new battery is reading 12.5 volts with the multimeter, so it has charge. (I didn't test the original battery voltage with the multimeter, which was an oversight). The battery leads seem securely attached. Any thoughts on what else to check before my friend has the car towed to a mechanic? TIA
Old Feb 23, 2025 | 05:11 PM
Chitown Fit's Avatar
Dreaded Push Button Start Recall.
You may have the Push Button start recall.
Push Button start Fits began having starting issues about three years ago.
There's a Honda Recall that had all Honda Dealers replace the Push Button circuit board for no charge.
Of this is the case,
Go to your local Honda Dealer to get the Push start Button circuit board replaced for Free. No charge.
Old Feb 23, 2025 | 06:45 PM
exl500's Avatar
There is a time/mileage limit, although I don't recall. Maybe 9 years/90k miles?
Reddogs
Nov 28, 2025 08:26 PM
Musicalpa
Dec 18, 2024 11:29 AM
Limmie
May 7, 2023 04:56 PM
bplegend
Dec 3, 2018 02:10 PM
alicia454
Dec 14, 2013 11:59 AM
