Help! Computer?
Old Oct 18, 2025 | 09:28 AM
Artman60's Avatar
Help! Computer?
I have a 2016 Fit, CVT, bout 200,000 miles. Got home from work Wednesday afternoon, all was well. Thursday morning started up and had antiskid, TPMS, engine, and steering icons all lit up, they did not go away. Battery was around 5 years old, so I got a new battery. Battery posts have 12.3 volts engine off, 14.6 volts engine running. I’m thinking maybe one of the computers??? Any help/advice/info is greatly appreciated! Thank you.
Old Oct 18, 2025 | 11:22 AM
bargainguy's Avatar
Welcome. You need to pull any error codes (DTCs) from the OBD-II port to figure out what's going on before proceeding.
If you don't have an OBD-II reader, many auto parts stores will read your codes for free.
Old Oct 18, 2025 | 02:25 PM
fibrepunk's Avatar
After replacing the battery, you need to drive around for like 30 mins for the warning lights to clear. Did you drive around or did you just swapped battery and expected all the light to clear up?
Old Oct 18, 2025 | 05:35 PM
Artman60's Avatar
I have put about 40 miles on the car since the battery swap. No change in icons. Thank you for the idea.
Old Oct 18, 2025 | 05:36 PM
Artman60's Avatar
I’m gonna call the dealer on Monday, see what the charge is just for diagnosing. Thank you
Old Oct 18, 2025 | 07:34 PM
2015FITEX's Avatar
thoughts on the battery senrorryy thing attached to the neg terminal on battery?
EDIT
runs fine? Zero issues.
BATTERY TERMINALS TIGHT?
wiggle retighten extra
POSSIBLE fuel injector issue........2015 ...thats me......is just waiting for this scenario <sad crying face>
GET A CODE READER...as suggested!
Old Oct 19, 2025 | 09:17 AM
bargainguy's Avatar
I've already been through fuel injector replacement at 88K (have 115K now).
Culprit code is p0420, raw fuel being dumped into the cat.
Injectors were replaced under warranty. I had to forward my VIN to Honda corporate to verify I had one of the early 2016 models under warranty, and they authorized the repair.
Old Oct 20, 2025 | 04:32 PM
Artman60's Avatar
Sunday night the icons went away, drove it to work and back (60 miles) no problems. Thank you to all who responded!
nayov
Feb 18, 2025 12:36 AM
Musicalpa
Dec 18, 2024 11:29 AM
tin
Nov 23, 2020 10:38 PM
incorpusyehtee
Dec 11, 2016 08:36 PM
4ow4ow
Dec 6, 2008 12:41 PM
