dim headlights
Old Mar 6, 2026 | 05:42 PM
Chitown Fit's Avatar
Halogen To LED's.
Originally Posted by bobski
All white incandescent (filament-based) bulbs get hot enough to evaporate their tungsten metal filament over time. Uneven metal loss creates hot spots on the filament, which evaporate faster until the filament breaks. Halogen bulbs add a gas (halogens being a group of elements on the periodic table) to the bulb envelope that bonds to the metal gas, forming a salt. When the salt hits the hot filament, it breaks down and re-deposits the metal, extending the filament's service life. This lets the Halogen bulbs run hotter (brighter, whiter light as well as faster metal evaporation) while retaining similar service life to non-halogen incandescent bulbs.
Silverstar bulbs run the filaments even hotter and even add a blue filter to the bulb glass to make the light even "whiter" (blue-er, increase the color temperature). There's no technological advancement involved - running the bulbs hotter reduces their service life. That's the sacrifice you make when going from the XtraVision line to Silverstar. Sylvania also pegs you as an impulse buyer when you make that jump, as even the base Silverstar (no fancy-ing letters or words) bulbs are around twice the price of XtraVision.
All the more reason to switch from Halogen light bulbs to LED light bulbs.
Old Mar 6, 2026 | 09:19 PM
bobski's Avatar
*Carefully* with well-informed choices.
From most important to least: LED emitters the same size and location as the halogen filament. 10-15 watts per "bulb". Higher CRI is always better (minimum 80 when I shop). Be suspicious if they don't specify CRI (it's probably terrible). Color temperature is a matter of preference - Halogen is around 3000K, 6500K is "HID" daylight-white, 5000K can be a nice middle ground with rich colors when paired with 90+ CRI.
Old Mar 6, 2026 | 10:09 PM
Bottom Line On LED's.
LED's are alot brighter and use less power than Halogen lights.
Kiro
Jan 24, 2026 10:04 AM
oman
Dec 21, 2017 10:10 PM
short1
Jun 29, 2013 12:38 PM
fujisawa
Sep 26, 2012 11:37 PM
doogiefish
Jan 24, 2007 11:58 PM
