Please Post Directions
Old Apr 10, 2026 | 09:14 AM
SilverEX15's Avatar
Several months ago, there was a lengthy thread about repairing the right-hand instrument cluster display. Because of bad soldering, the display sometimes gets dim or goes blank. People posted great directions about removing, soldering, and reinstalling the cluster. I know I had saved all of that, but I can't find it. If anyone could post that info, I'd be grateful.
After working fine for months, my display - mileage and fuel level - went blank a couple of days ago.
Old Apr 10, 2026 | 09:16 AM
bargainguy's Avatar
Old Apr 10, 2026 | 09:52 AM
SilverEX15's Avatar
With the help of the posts above and YouTube, I have some information.
Removal and soldering -
Removal of the cluster -
Listing of videos -
Individual videos of the removal process -
Old Apr 10, 2026 | 11:47 AM
bobski's Avatar
I haven't watched those videos - but having done lots of electronics rework professionally, remove as much of the old solder as possible. The solder joints cracked because the specific solder alloy they used is too brittle. Get rid of as much of it as practical and apply something else. Just adding flux and re-flowing the original solder will not fix the root problem, it may not even fix the cracked joint.
There's lots of different solder alloys, but 60/40 or 63/37 tin/lead (optionally with a few percent silver) is considered the gold-standard by most hobbyists. RoHS regulations understandably prohibit its use in production electronics because of its (substantial) lead content. Electronics manufacturers have come up with some more exotic RoHS-compliant metal mixtures in search of an ideal substitute (strength, ductility, melting temperature, electrical conductivity, metal wetting, surface tension, corrosion stability, crystallization properties, and of course cost - it's complicated).
Back on point, the original solder alloy was mechanically not up to task. Remove it and replace it with something that is. Rosin-core tin/lead (Sn/Pb) should work nicely, the stuff with ~2% silver (Ag) has even better mechanical strength and fatigue resistance (an inadequacy of one or both of those probably caused the cracks in the original solder joints).
As for removing the solder, I'll suggest a plunger-style desoldering iron. Not just a plunger-type tool, but one with a hot tip that plugs in and melts solder on its own. I have a "Tenma Desoldering Tool" that works well enough, especially considering its $20 price tag. Desoldering stations with the pump in the base are problematic, as the long hose out to the hand piece slows the vacuum ramp-up. Pump-in-the-hand-piece is the way to go.
A temperature-controlled soldering iron can save a lot of time, headache, and even circuit board damage. I hear the Pinecil has great bang-for-your-buck. There's lots of similar products out there though (small handle with OLED display and a few buttons, accepts 12-24V DC, USB-PD, or battery pack for power) - keep an eye on the price of the tips, as they have the heater built in. If you want something more substantial, Hakko and Weller both make excellent entry-level soldering stations, as well as professional units.
Old Apr 10, 2026 | 12:12 PM
SilverEX15's Avatar
Thanks for that. I have 63/37 solder and a Yihua soldering station with temperature control. I also have a solder sucker and solder wick. I'm saving your post.
When I eventually get around to doing this, I'll post about it.
Old Apr 10, 2026 | 01:57 PM
bobski's Avatar
The desoldering iron is very much like the a plunger-style solder sucker. It just eliminates the race when melting the solder with the iron, then getting the sucker in place on the solder joint before it solidifies. It makes the iron and the sucker the same tool.
Wick can also work, but you'll be spending a lot more time with the circuit board at molten solder temperatures, waiting for the solder to flow into the wick. Use the widest tip that will fit in your work area on the PCB, as it will carry heat from the iron heater to the wick and PCB faster. Though really that advice stands for soldering in general.
Old Apr 11, 2026 | 05:42 AM
nayov's Avatar
Wow, what mess. Looks like there are services that repair for $170 (quick search). I can't see the average Joe (me) doing this without wrecking the circuit board. I'm DIY almost 100%, but I know my limits and risk tolerances.
Old Apr 11, 2026 | 09:24 AM
SilverEX15's Avatar
Yes, I've seen them in use. I wouldn't have enough use for one to justify the cost.
Old Apr 11, 2026 | 09:51 AM
bobski's Avatar
That's around twice what I would consider to be a "fair" price for the job. With professional tooling, you're looking at maybe 5 minutes of actual rework time. The rest would be disassembly, reassembly, and presumably testing of the cluster. Find a local shop, bring them the cluster opened up with the solder joints exposed, ideally marked. Reassemble and test your self (plug it in to the car). I would be surprised if they charged you more than $50.
Sham24
Apr 14, 2026 05:35 PM
SilverEX15
Apr 10, 2026 08:17 AM
sh4217
Apr 9, 2020 04:04 PM
MTLian
Sep 9, 2013 07:11 PM
dtmbmw325i
Mar 5, 2010 02:39 PM
