2018 Honda Fit - revving sound when starting (video)
Old Apr 15, 2026 | 05:03 PM
Aqualset's Avatar
Hello, we have a Honda fit that makes a revving sound about 1 every 5 times we start it. Any ideas?
Link to video: https://drive.google.com/file/d/1PLEFFuaYiNYvu3s-yTRZkbyfd-d-90rC/view?usp=drivesdk
Old Apr 15, 2026 | 07:13 PM
bobski's Avatar
YES. Our 2020 EX makes the same noise. I don't have a diagnosis, just saying you're not alone.
Unrelated: If you're sure your tire pressures are okay (you've checked them), use the buttons on the bottom right of the steering wheel to go into Settings > Calibrate TPMS to make that message go away.
Old Apr 15, 2026 | 07:40 PM
bargainguy's Avatar
All GK5 models 2015 and onward suffer from a weak return spring in the (OEM) VTC actuator.
The weak spring causes direct contact with the timing chain at startup before oil has a chance to get into that area. This could be the noise you're hearing.
My GK5 (2016 LX) did this at startup starting around 60K. It was worse after sitting cold overnight.
The bad news is that timing chain wear only gets worse. It can eventually stretch the timing chain, and if the chain slips, goodbye engine.
The spring is a $24 part. The problem is the labor to get there.
https://spring-start.com/shop/ols/pr...pre-order-sale
Old Apr 15, 2026 | 07:56 PM
bobski's Avatar
The problem was supposed to be fixed with a redesigned actuator for the last few model years and any older cars that had been serviced for the issue. Is this what the original VTC actuator problem sounds like? I seem to recall hearing something else when I went looking for VTC actuator videos. Aqualset's video captures the sound very well IMO.
Old Apr 15, 2026 | 09:10 PM
FitFun1979's Avatar
Yep, that's the VTEC actuator.
Many state that it's "only cosmetic" when in fact it slowly stretches the timing chain.
Leave it long enough and you'll be replacing valves, pistons etc.
The main culprit is extended oil change intervals (recommended by the oil life monitor).
I had the same issue on my 2016 (when I purchased it in 2020).
Luckily the car was still under warranty and Honda paid to fix it properly.
Some state that there's an "improved" actuator, when in fact it's just the same part as before.
Fast forward 6 years and I still haven't heard the noise return.
I attribute it to my stringent oil change intervals of every 6 months (or 3k miles).
It's a tiny sump, and that direct injected system dumps a lot of fuel into the oil, especially in city driving.
Old Apr 15, 2026 | 10:36 PM
bobski's Avatar
VTEC is different from VTC, though they can be combined on the same engine (the case on the L15B1).
VTEC lets the ECM switch which camshaft lobes a given set of valves is following. Such as having the intake valves follow a low-lift profile that's good for torque and efficiency at low to mid RPMs, then a high-lift profile that maximizes peak power at high RPM. Or the previously-known-as-VTEC-E setup where one intake valve effectively stays closed at low RPM, which causes combustion-stabilizing swirl in the cylinder - useful for lean-burn operation.
VTC is variable cam timing, which Honda sometimes calls iVTEC. It lets the ECM change the timing of one or both camshafts. The camshafts still turn at half the speed of the crankshaft, but the exact alignment of the cam and crank can be varied, similar to how the ECM varies ignition timing according to engine speed and load.
It's possible to bake cam timing change into VTEC cam profiles, but VTEC is an on/off mechanism. VTEC cam timing changes would also have to be on/off all-or-nothing changes. VTC lets the ECM adjust the timing anywhere within a range of values, to match the exact situation.
Old Apr 16, 2026 | 12:16 AM
FitFun1979's Avatar
That's incorrect.
According to the Honda service receipt, it specifically states:
"09-010 1101Z9 Replace the VTC actuator"
1 x 14310-5R1-013
Old Apr 16, 2026 | 12:41 AM
bobski's Avatar
That's incorrect.
1 x 14310-5R1-013
What's incorrect? Your first post? You can edit it.
Old Apr 16, 2026 | 09:39 AM
FitFun1979's Avatar
My posts are consistant.
If you have a problem with Honda's naming scheme for their parts, please take it up with them.
I'm only here to assist those with accurate information as it relates to my experience with the product.
Old Apr 16, 2026 | 10:58 AM
bobski's Avatar
Sigh.
"Replace the VTC actuator"
Again, VTEC and VTC are two different things. The "VTC actuator" is built into the intake cam gear. The closest thing you get to a part named "VTEC actuator" is the valve rockers. The rockers have oil-pressure-driven / spring-return pins in them that lock multiple rockers together. VTEC = switching cam lobe shape. VTC = variable cam phasing (twist).
VTEC is controlled by 15810-5R0-003 Valve Assy., Spool (ROCKER ARM OIL CONTROL VALVE).
VTC is controlled by 15830-5R7-A03 Valve Assy., VTC Oil Control (VTC OIL CONTROL SOLENOID VALVE)
Two different systems doing different things, both in the cylinder head, both related to the camshafts.
Old Apr 16, 2026 | 04:58 PM
Chitown Fit's Avatar
Honda Fit "Know It Alls".
You Honda Fit all knowing dealer hating "Einstiens" should open your own Honda Fit repair shop. So us mere mortal Honda Fit owners can get our Honda Fits maintained and serviced from your all knowing knowledge. 🧎‍♂️🧎‍♂️🧎‍♂️
Old Apr 16, 2026 | 05:34 PM
bobski's Avatar
Resistance is futile. You will be educated.
Aww. The forum won't let you post in all-caps.
Old Apr 16, 2026 | 08:18 PM
Male Feminist.
Typical male feminist.
Tone policing.
It's not what is said.
​​​​​​​It's how it's said.
Old Apr 19, 2026 | 08:55 AM
t-rd's Avatar
You need to replace the spring with that one mentioned above from Spring Start + the timing chain tensioner.
Old Apr 21, 2026 | 11:14 PM
MTLian's Avatar
Man, such a bunch of negative Nancies on the forum now. Sheesh.
it does definitely sound like the VTC actuator. To solve the issue, you can replace the spring inside the actuator yourself. You can buy the spring for really cheap and if you aren’t game to do it yourself, I’m sure it wouldn’t be much more than a few hours labor with a mechanic you trust. Here’s a DIY video made by a FitFreak forum contributor. He gives a link to where to buy the spring.
Old Apr 22, 2026 | 12:19 AM
Negative Vibe.
Because a few think they're "Einsteins" about everything Honda Fit.
I know nothing about a Honda Fit.
I just drive my Fit.
When it needs repair or maintenance I let my pit crew Honda Dealer take care of it.
Old Apr 22, 2026 | 08:44 AM
t-rd's Avatar
I replaced the spring last year with the higher tension one and a month ago it started rattling again so I replaced the chain tensioner also. This is the suggested best solution from Spring Start. If you take it to the dealer, they will replace the whole sprocket, which is really the same thing as replacing the loose tension spring inside the VTC actuator pin but at a higher cost.
Old Apr 22, 2026 | 09:01 AM
bobski's Avatar
I find it odd that our VTC rattle started up soon after the first out-of-warranty oil change. Has anyone tried higher cold-viscosity oil (5w-x, 10w-x) as a band-aid fix? That seems like exactly the kind of thing a dealer would do to avoid a backlog of high-labor low-profit VTC warranty work.
Old Apr 22, 2026 | 12:19 PM
t-rd's Avatar
The right fix costs $160 and some of your own time if you are mechanically inclined. So a band-aid fix is not as good of an option.
Old Apr 28, 2026 | 09:33 AM
bobski's Avatar
No improvement from 5w-30 (Kirkland Synthetic). Ordering a spring kit and gaskets.
