MODS/ACCESSORIES for the GK
Old 10-10-2017, 11:59 PM
[LegenD]'s Avatar
Originally Posted by TougeMonster_GK5
Its an old publication, but atleast I have references for what should be available in the Japanese market! Hyper Revs gotta come out with a new magazine release!
That red one is intense! Kind of neat spoiler. Is it worth getting this? Generally love this magazine and own a bunch. I was just wondering since a lot of parts might not fit our USDM models. Anyway, thanks for sharing
  #1602
Old 10-14-2017, 04:13 AM
hasdrubal's Avatar
Installed Megan Racing springs with Koni Orange shocks yesterday. Did all the work myself, which is probably why I'm getting a small clunking noise from the right front. Think I need to check the upper mount. Body roll and dive on braking is reduced as you'd expect, pretty happy with the result.
It would be great to do a comparison drive against a GK with Swift springs and Konis, the specs show them to be slightly softer than the Megans and about the same drop. Went with these because they were about half the price.
  #1603
Old 10-16-2017, 01:18 AM
hasdrubal's Avatar
Sirius LED headlight bulbs, photo shows vs stock on the right. Not a perfect upper cutoff, but think it should be clean enough to avoid blinding other drivers. Need to adjust the beam down a bit to make sure.
  #1604
Old 10-16-2017, 12:18 PM
FitHundreds's Avatar
Originally Posted by Guillermo Rodriguez
what wheels are those?
This is the rota copy of the CE28 volk rays
  #1605
Old 10-16-2017, 12:22 PM
Originally Posted by kenchan
good job! yah, modern FWD based cars have wider stance on the front it seems. you can balance that out with:
1. camber bolts on the front and give it -2 degrees.
2. run 5mm spacers with steel lugs on the rear to push them out a tad..unless you want to go ahead and replace to longer studs, run 8mm on the rears.
GL
Yeah, I noticed that, changed the tires from a 205/50 to a 205/45 doesn't poke out that much rather than before. Now I just need a spacer at the rear to balance it out. Thanks for the advice man.
  #1606
Old 10-16-2017, 01:24 PM
TougeMonster_GK5's Avatar
care to share part no. And where u purchased? Did u experience any bogging/loss of power with them turned on? Did u upgrade your battery too? I wanna upgrade to LED too! Thx in advance!
  #1607
Old 10-16-2017, 01:29 PM
hasdrubal's Avatar
https://www.siriusledlights.com/coll...d-headlight-h4
Cost was $50 for the pair, no loss of power and still on the stock battery. The page doesn't say anything about how many watts they draw, I'll have to go dig through the packaging.
  #1608
Old 10-16-2017, 02:43 PM
sneefy's Avatar
How's the performance on the road with these?
  #1609
Old 10-16-2017, 03:18 PM
2Rismo2's Avatar
The top cutoff doesn't appear to be very good on those IMO. There seems to be a lot of light bleeding off.
  #1610
Old 10-16-2017, 03:21 PM
sneefy's Avatar
Agreed. Grated it's hard to tell from one photo against a garage door, but the throw seems narrower as well. Bright, but the light does not seem well (properly) controlled.
  #1611
Old 10-16-2017, 03:33 PM
hasdrubal's Avatar
It's not as clean as the stock bulb, I did mention that in the first post. It does produce a lot more light, and it's a dramatically better pattern than I've seen with HID bulbs in a halogen housing. Compared to an HID projector retrofit, or somehow swapping for a factory LED light assembly from another Honda, it's far cheaper.
Visibility while driving is dramatically improved, and with proper adjustments for aim I think it's worth keeping on the car. However, if anyone finds a bulb that produces a better/stock-like pattern and still throws as much light, I'd be happy to check it out. The only thing I have invested in these is the $50.
  #1612
Old 10-16-2017, 06:11 PM
Thanks for sharing! Just ordered a set! Should dramatically improve night vision during late night canyon carving
cheers
  #1613
Old 10-16-2017, 07:58 PM
axlline's Avatar
Got my Clazzio seat covers installed. Ordered them the beginning of August, they got here Thursday. Took three hours to install, not hard at all. The stitching matches my Kenstyle wheel great.
  #1614
Old 10-16-2017, 11:46 PM
first honda's Avatar
covers look great
Very nice wheel cover too
49 avg mpg very impressive
  #1615
Old 10-17-2017, 08:28 AM
I got these LED from SuperBrightLED.com. Did both the Headlights and Fog lights. Low beam, hi beam.
Attached Thumbnails MODS/ACCESSORIES  for the GK-img_1012.jpg   MODS/ACCESSORIES  for the GK-img_1014.jpg
  #1616
Old 10-17-2017, 08:40 AM
sneefy's Avatar
They look pretty good. Which ones did you get?
  #1617
Old 10-17-2017, 08:53 AM
abueloloco's Avatar
Pictures don't show up. Which ones did you get? Looking to get a set for my car.
  #1618
Old 10-17-2017, 09:08 AM
H4-HLV4 LED Headlight Kit
H4-RL650-H Headlight Load Resistor Kit
H8-WHP28-DRL Fog
Load resistor boxes are mounted with just thick double sided 3M sticky tape in any open space.
Have to make sure to put the headlight in the correct way, and not upside down, otherwise they will be blinding other drivers. The instructions are clear on this as there is very small screw that defines the correct way to put them in.
  #1619
Old 10-17-2017, 01:34 PM
nisco's Avatar
Recently installed Acuity Instruments Throttle Pedal Spacer. Has made heel-toe much easier, and downshifts a lot smoother. I've also created a DIY installation thread, if you guys are interested!
CLICK HERE FOR INSTALLATION
  #1620
Old 10-17-2017, 04:03 PM
These just arrived on my desk today.. i think ill play before installing the shoes, might not ever get to it tho, been waiting damn over 2 years for this release!
Quick Reply: MODS/ACCESSORIES for the GK
