Ignition-Switched Power
Old Aug 10, 2014 | 09:58 AM
SilverEX15's Avatar
Aside form the 12 volt outlet, where can I tap in to get 12 volts that's on only when the ign is turned on?
Or, how can I tap into the wire for the 12 volt outlet?
Old Aug 10, 2014 | 03:05 PM
noripwr's Avatar
When I was taking out the driver side cover to install the interior illumination kit, there was a green and red wire spliced to it to a plug that seemed to serve no purpose. My voltmeter indicates it has a 12V running in it so you could probably use that to power a couple USB or other purposes.
Old Aug 10, 2014 | 04:09 PM
SilverEX15's Avatar
Thanks. Where is that "driver's side cover"? I removed the panel with the 12v and HDMI outlets and can tap into the 12v outlet wire.
I wonder what that unattached wire is for.
I'd also like to make use of those blank switch locations to the left of the driver - by the traction control button.
I have a recent post with pictures.
Old Aug 10, 2014 | 04:23 PM
noripwr's Avatar
Oh that's what I mean, the cover where the econ button and traction buttons are. There's a leftover plug with the wires I mentioned in basically a perfect location for those that wanna set up an extra USB slot for charging phones etc.
Old Aug 10, 2014 | 04:25 PM
SilverEX15's Avatar
Interesting. I'll take a look at that.
Shravan S. Dwarka
Mar 19, 2017 07:25 PM
faridango
Jul 1, 2015 10:16 PM
polokid69
May 10, 2010 12:50 PM
krissnkev
Jun 6, 2008 04:18 PM
hogsniper
Mar 13, 2008 06:22 PM
