Tick, tick, ticking (engine)
Old Sep 15, 2014 | 03:11 PM
nijkap's Avatar
Originally Posted by Pf9938
When you said you felt the misfire what does it feel like? Sometimes when I am stopped at a light I feel the car move a bit as if a car lightly tapped me from behind. I check to see if someone hit me but it was just the car doing it on it's own. Is this what it would feel like?
This happens to me too....
Anyone else?
Old Sep 15, 2014 | 04:28 PM
Derka's Avatar
Depending on the tick like the others said the direct injection is always a little loud at first, When you've never had a car that had DI it always takes a little to get used to. I remember is 2008 our Mazdaspeed 3 freaked me out with all the noises.
Old Sep 16, 2014 | 08:09 PM
nijkap's Avatar
Not the ticking, I realize that may be normal. But in regarding the slight tap movement when the car is stopped at a light that PF9938 described . It feels like it moves an inch or so. Anyone else getting this?
Old Nov 23, 2014 | 12:31 PM
trashercan's Avatar
Valve job ???
Originally Posted by jschodtler
After a valve job at 800 miles my ticking noise went away. Car was running rich and miss firing on 3 cylinders. I could hear and feel the miss fire at idle with the ac off. Good as new and now quiet too.
You state that the noise went away after this at 800 miles, is it still quiet and if so what did you ask your dealer to do for you, ie what legitimate valve maintenance was there to do because my dealer told me this was a normal sound and there was nothing I could do about it.
Thanks
phenoyz
Nov 11, 2016 01:34 AM
AFittingName
Sep 24, 2015 01:17 PM
lapislazuli
Sep 13, 2014 10:21 PM
hydrogennine
Sep 7, 2011 11:59 PM
Fit4Pits
Aug 3, 2009 12:35 AM
