2015 EX-L Cup Holder Removal?
Old Sep 15, 2014 | 10:40 PM
eCity Fit's Avatar
I have the EX-L and want to remove the two cup holders in front of the shifter. How do they come out? Has anyone done this on the 2015? If so, any advice would be appreciated!
Old Sep 16, 2014 | 01:03 AM
noripwr's Avatar
SilverEX has a couple pictures. Anyway you need to remove a screw where the HDMI, 12v, usb inputs are. Then pull that out. Once you have pulled that out and removed the usb, hdmi, and 12v plugs, you will see another screw that holds the cup holders in. Unscrew that then pull the cup holder up and out.
Old Sep 16, 2014 | 01:16 AM
acter's Avatar
Oooooh.. does that mean I could put in the better cup holders from a Civic? The ones with the "tension" thingies? (What?! It's a technical term.)
Old Sep 16, 2014 | 01:35 AM
noripwr's Avatar
I don't know how the civic cup holders look. But the tray behind the cup holders to store stuff is one with the cup holders. They are together as one unit. Also, there are no sides to the cupholder, so enough liquid would go down the sides, but it seems Honda put some form of absorbent (three of them) under the cup holder area to "dry" that area of moisture.
Old Sep 16, 2014 | 08:17 AM
acter's Avatar
Hope this works...
Here is a picture of them:
http://www.productwiki.com/upload/im...cup_holder.jpg
Those are spring loaded, so you can put different sized cups or bottles in there, and they won't wiggle.
Old Sep 16, 2014 | 01:51 PM
eCity Fit's Avatar
Thanks for the info! I looked at it today and realized that it indeed is not part of the gear shift trim. I was thinking that it was all one piece. Thanks again!
Old Sep 16, 2014 | 02:43 PM
noripwr's Avatar
Originally Posted by acter
Hope this works...
Those civic ones definitely won't fit. Sorry to disappoint ya.
Shipoffools
Feb 21, 2018 09:40 AM
Press Fit
Feb 12, 2018 09:03 AM
feldmakg
Jan 23, 2015 06:46 PM
littleblackcar
Nov 24, 2011 07:55 PM
Hocker
Jan 9, 2008 10:17 AM
