Adding Switches
Old Sep 21, 2014 | 02:09 PM
SilverEX15's Avatar
Adding Switches
I wanted to put switches in those cut-outs to the left of the steering wheel, but I wasn't able to find switches that would fit the opening. Long story short, I bought these at Autozone. I drilled a hole through the center of the plate, and inserted the switches.
The switch on the left controls two 12v outlets I installed, and the one on the right turns on LED colored lighting.
This is a bit blurry, but you can see how I ran the wires through the hole in the plate and to the switch. I had to clean out the area inside the plate to fit the nut that holds the switch in place.
The terminals are close together, so I used Liquid Tape to insulate them.
Here is the switch I got from Autozone. I like those fuse holders, too. I use them whenever I put in anything electrical.
Old Sep 21, 2014 | 02:12 PM
accordguyintake's Avatar
thanks for sharing!
Old Sep 21, 2014 | 04:12 PM
cheesewhiz's Avatar
Apparantly Jason Truong is more impressed with himself than your Switch Modification!
Another nice write up ... good job!
Old Sep 21, 2014 | 04:55 PM
huh? lol I have a switch on my 08' Fit as well in the same location, so I was just giving props for taking the time and showing us how it was done. Mine hooks up to an array of interior LEDs
I installed a 2(?) way switch so it acts exactly like the dome light, "On" "Door" or "Off" mode
Old Feb 28, 2015 | 08:43 PM
Pat Furrie's Avatar
SilverEX15,
How did you get the switch blanks out of the dash?
Thanks
Old Mar 1, 2015 | 03:26 AM
DrewE's Avatar
Assuming it's like the older models, you pull the section of dash off its clips (which it is designed to do for access to various things), and then they unclip easily from the back by squeezing the long prongs together slightly. It's rather easier to understand when you see it from the back, but not the easiest to describe.
Old Mar 1, 2015 | 07:14 AM
SilverEX15's Avatar
Originally Posted by Pat Furrie
SilverEX15,
Thanks
I pried them out with a screwdriver.
EDIT: Come to think of it, I might have used a penknife and pushed straight into the dash as soon as I could to pry it out that way. It's not a big deal. I've pried mine out several times as I was playing around with adding switches. The picture sows the scratch marks from my first rough attempt. No big deal.Name:  Cy2mEXC.jpg
Old Mar 1, 2015 | 08:13 AM
Pat Furrie's Avatar
Thanks. I suppose all the removals after the first time aren't so bad, once you get a feeling for how it is supposed to come out. My concern is not knowing quite how the panel comes out, and end up damaging something on my one-week-old Fit.
Thanks again for the info
Old Mar 1, 2015 | 09:09 AM
SilverEX15's Avatar
I didn't want to remove that panel, and luckily, I didn't have to.
Although there is no Shop Manual available for the 2015 Fit, there are detailed directions for taking things apart available online. I've downloaded and saved several.
Old Mar 1, 2015 | 04:28 PM
DrewE's Avatar
By the way, these installation instructions for the ambient lighting accessory describe how to remove this lower dashboard panel (among a number of other steps). I see that it's rather more complicated than on the GE8, where this portion was literally a little hinged door sort of arrangement and a five-second pull on a moulded-in handle sort of thing gives access to the blanks.
Old Mar 1, 2015 | 05:49 PM
SilverEX15's Avatar
Right! College Hills. I couldn't think of the name. I got some things from them. Right on the outside of the box it says that directions are not included, and it tells you where to look online.
Old Mar 1, 2015 | 07:37 PM
Pat Furrie's Avatar
Excellent! Thanks for pointing me in that direction. Had done several web searches, trying to find something on that order. How did you find it?
trashercan
Mar 13, 2015 04:13 PM
SilverEX15
Aug 26, 2014 09:53 AM
stock0891
Jan 28, 2011 04:27 PM
caliban10010
Aug 28, 2010 06:51 AM
Lyon[Nightroad]
May 2, 2010 02:12 PM
