What brand and grade of gas are you using? 87 or higher?
People (including the dealer) have said that it's good to use a non-ethanol gas once a month because the Fit has direct injection, and that can results in deposits building up.
Well scratch that idea. I just Googled it. Read the article linked below. "For years we’ve been taking apart engines in our shop and making repairs on them, and we have found consistently that vehicles using ethanolblended fuels are much cleaner inside than ones that are not. This starts at the fifth paragraph.
Mechanics Corner: It All Starts With the Fuel - Vital | A news & media resource published by POET (vitalbypoet.com)
All fuels have the same additives so there really is no "Top tier" gas. its all marketing BS.
but why?? it does nothing but waste money. My type-r says 91 or higher and don't even go with 93 unless 91 isn't available at the station.
All ECO does is make the throttle response terrible so you can't get up to speed as fast, therefor you might save a little gas. it makes very little difference in gas mileage. You can do the same thing in non-eco mode if you want, just grandma it after every stop.
Honda recommends Top Tier gas for their vehicles because they feel that the additional additive strength that Top Tier provides is of benefit to their engines. You of course are under no obligation to buy Top Tier but are free to fill your car with minimal standard gasoline, typically for a cheaper price.
Your engine is going to be gunked up at the intake valves LONG before the inside of the combustion chambers. one tank of something once in a while isn't going to change the small amounts of build up in there.
Well - What is Top Tier Gas and Is It Worth It? (autolist.com)
Neither my BMW nor Fit like 87.
Both show improved (overall) performance on 91.
Only vehicle that I wasn't able to notice any difference on, was my 07 Focus.
That thing was a total turd from the beginning to the end when I sold it.
All fuel must meet a MINIMUM requirement put forth by the Federal Government. The ADDITIVE packages added to this minimum requirement fuel are PROPRITARY formulas of their respected oil company.
Some fuel facts most people don't know...
1: Chevron makes the best fuel.
2: Chevron is NOT sold in Detroit.
3: Detroit auto manufacturers have Chevron fuel trucked in for all their engine certification runs.
4: Those tanker ships running up and down the coast carry fuel for multiple oil companies. Its one reason why if one refinery has an outage, everyone's fuel goes up. Being related to a tanker Capt. has taught me this.
5: Local Depots will sell gas to many different sellers, not just their own. Example, the Arco (yuck) depot in Bell, CA sells fuel to all the cheap gas stations as well as their own. The only difference is Arco adds their additive package as the tanker truck is being filled. Like going through a car wash and one person selects wax while the other person doesn't. I watched them do it and asked about it while doing in-frames.
6: Octane is NOT an additive. Its a RATING. You don't add octane to fuel. You add additives that changes the octane RATING of that fuel. Octane is a KNOWN gas that is burned in a lab as a baseline. Then they burn gasoline and compare the two. 87 octane rated fuel burns faster and hotter than 92 and exhibits lower emissions. Higher octane rated fuel burns SLOWER and is more stable in higher compression engines. These additives in a higher rated octane fuel can actually damage cheaper catalytic converters. Its why the cats for a Corvette is so expensive. An engine designed to run on 87 octane will actually loose power when running 92. The higher performance are not getting their power increase from the fuel, they get it from the higher compression/boost where a more stable fuel is required. (people are going to hate me for this fact).
7: If your car was designed to run 87, run 87. If you can buy Chevron; its the cleanest burning fuel.
8: If you boosted your engine, then you will need to run a higher rated fuel. When power drops off, have your stock cats checked if you didn't bypass them. A simple differential pressure test will reveal lots!
9: None of this is BS...as you say.
In the 2015 Fit manual on page 347, it mentions that unleaded gasoline, grade 87 or higher should be used, but also talks about Top Tier detergent gasoline, especially to avoid MMT (manganese-based fuel additives).
1) Which one do you use and why?
2) Do you really notice a difference using 87 vs. 91 or 92 grade?
I was using 87 from Valero on my old Honda, but didn't know if I should consider using a higher grade with detergent additives. Arco, Shell, Chervon?Thanks.
But I have found that the sweet spot for the best FIT gas mileage is setting the cruise to 55 MPH. (There is a song..."I can't drive 55!") When you get over 65 MPH, and especially over 75 MPH--your MPG's really deteriorate on FIT. FIT is also very sensitive to tire pressure--If your tires drop below 33/32 PSI you will pay for it a bit in fuel costs and the wider/heavier tires on my FIT also eat away at MPG's.
You can see that for the life of my FIT the MPG's are 31 AVG. That is because I drive a lot in the city and with my heavy BF Goodrich Comp TA tires you pay for it in fuel in Stop and Go but are rewarded with an incredible ride, stability and control on the highway or track at speeds in excess of 90 MPH on FIT.
At 55 mph i average 65 mpg. Running Firestone FR740 tire. That what came on my Fit when i bought it. Looking at different tires when these wear out. See whats available then. Friday my grill will be here and be installing that and the led upper tail lights.
Low 40's is the best MPG's I have ever got on the car since new if I am 90% highway on that tank.
City only No AC about 28 MPG.
City only with AC about 25 MPG.
