high RPM in highway
Old Sep 26, 2014 | 12:40 PM
m_x's Avatar
m_x
Originally Posted by Fox944
I drive 70mph to work everyday. Engine noise is hardly an issue. The wind and tire noise are much louder and i can barly hear the engine. With the audio system on, i dont hear it at all.
That said, i prefer the higher rpm as the car is always in its powerband and feels more spirited. Domt meed to downshift for passing power either. Although a 7th cruising gear would be nice for long trips.
^This. Relax and drive it. Any "increased wear" would be negligible if you are maintaining the engine and changing the oil on time. The body panels will rust through before either engine dies.
The CVT was widely reported as being buzzy in its own right and whether you agree or disagree on that point, it is at least evidence that you are not simulating anything by putting it in a lower "gear" or revving it up over 3k. It is different, plain and simple. To say you revved the CVT high on a test drive and it was loud seems like almost a moot point.
I drive on the highway to and from work everyday (60 miles) and I too was concerned about noise and high revs when deciding between the two. Now, after 6 weeks and 4,000 miles, it really is not an issue. I catch myself at 80+mph (around 4k) and don't notice engine buzz over the wind noise and tires, which would be identical in the CVT. I haven't driven the CVT at highway speeds but I have to doubt "quieter" would be my adjective of choice. I did test drive the CVT twice before buying the M/T and found them BOTH to be loud at lower speeds when the wind noise isn't drowning the engine out. The manual is more fun though.
They definitely could/should have made 6th a little longer, but you shouldn't write off the Manual just for that. The red line is at 6,750; why worry that the engine can't handle extended periods between 3k and 4k?
Old Sep 26, 2014 | 01:35 PM
Fox944's Avatar
If anything, I would assume the manual's engine will outlast the CVT due to the fact that it runs higher rpm. Less carbon build up.
anyone worried really has no reason to be.
Old Sep 26, 2014 | 03:49 PM
rodney's Avatar
Originally Posted by jaydmalex
owners of 2015 Fit with 6 mt, do you guys get a high rpm while driving like 75 mph and the rpm is about 4,000 ish, I cant recall to be exact,
i just got home from my commute. i thought of this thread, and made sure to pay attention to mph/rpm. i am spinning 3800 rpm @ 80mph.
if you car is spinning 4000 @ 75mph, you will need a clutch....
CyclingFit
Dec 28, 2017 12:39 PM
Myxalplyx
Dec 6, 2015 07:36 PM
Myxalplyx
Jun 30, 2015 09:09 PM
mike410b
Jan 29, 2015 07:01 AM
wsalopek
Apr 12, 2006 12:18 AM
