Stopping the Car and Listening to the Radio
Old Sep 25, 2014 | 06:04 PM
SilverEX15's Avatar
A couple of weeks ago, someone was asking how to shut off the engine and keep listening to the radio. I don't know if he got an answer, but if you shut off the engine in D, the radio will keep playing till you put the car into P.
Old Sep 25, 2014 | 06:14 PM
rodney's Avatar
the person that posted that question has a 6mt, manual transmission, thus has no "D".
Old Sep 25, 2014 | 06:27 PM
Fox944's Avatar
all one needs to do is hit the start button twice while without your foot on the clutch and it will go into accessory mode. Akin to twisting a key (standard ignition) to the number 2 position but not actually twisting far enough to crank the engine.
Old Sep 25, 2014 | 06:37 PM
rodney's Avatar
nope, doesn't work. just did it 2x to double check. you have to shut the car off, then turn it back on to acc mode.
Old Sep 25, 2014 | 08:29 PM
Fox944's Avatar
Correct. Did not Understand what you're asking I thought you meant how do you engage accessory mode but now I realize you're asking if you're able to shut the car down after driving, while remaining in accesory mode. I dont think thats possible.
Old Sep 25, 2014 | 09:29 PM
noripwr's Avatar
I find it interesting how when putting the shifter to N, pulling the E brake up, and then hitting the Start/Stop, the radio will stay on but the screen in the dash will say to Put Shift to P. The car knows!
Old Sep 25, 2014 | 10:08 PM
SilverEX15's Avatar
I wonder if hitting the Stop button while the car is in gear would do the same thing.
Old Sep 25, 2014 | 10:09 PM
SilverEX15's Avatar
I can get the radio to turn on by pressing the Start button once. If I press it again, the instruments lot up.
Old Sep 25, 2014 | 10:20 PM
rodney's Avatar
nope, the car doesn't know it is in gear. i did try reverse too, since there is a reverse light switch plumbed in. no dice.
Old Sep 26, 2014 | 03:39 PM
xorbe's Avatar
We have a different brand car with the same issue. I can't figure out how to turn the engine off without losing the radio, and then having to turn the radio back on. First world problem, but this is a regression from keyed vehicles ...
graphixgurl
Feb 4, 2014 03:34 PM
awptickes
Jul 22, 2010 04:32 PM
prelude_guy97
Sep 25, 2008 04:48 PM
Digimer
Jun 2, 2007 04:17 AM
benfal2001
Sep 24, 2006 01:55 AM
