slammed my GK from philippines
.... it's pricey, RECARO has seats with side airbags on them.
Thanks for the info.
Thinking about lowering my car by 2.5cm to 3cm.
Running 17x7 43 wheels + 205/45/17 tires
From your experience, do you think this setup going to rub? do I need camber kit?
Thanks
Thanks
The rear won't rub, front wheels might. Safer to just try it out first before doing the camber bolt for the front
Front is 17x7.5 38 offset plus 5 mm spacer to clear brakes. Final offset is 34mm. Rubs on hard dips only. Tires are neuton nt 5000 they run narrower than a regular 205/40/17
Rear is strait 17x7.5 38 offset same tires 205/40/17
Update pics june 26, 2015. Installed Work Seeker CX wheels. After 7 mos wait.!
1183BC70-C103-4C88-A616-81DEA75.jpg?1435282476897&1435282478590&1435282530815&1435282579778
Lip
Hi, where did you source the lip? Very interested. And do you think the GK will fit 17x8.5 wheels? Planning on swapping my stock wheels with some ce28's but I'm worried about rubbing... thanks in advance!
What wilwood kit did you use ? I'm asking because on the wilwood page they don't have a kit for our cars listed yet.
