Dashcam cable routing
Old Nov 9, 2014 | 09:26 AM
NotBlake's Avatar
Cheesewhiz asked about dash cam installation, so I put together a quick video showing how I routed the cables for my G1W-H. Thought I'd throw it up for posterity.
Old Nov 9, 2014 | 12:49 PM
Vanguard's Avatar
Once again, Great job! Thanks for this information.
Old Nov 9, 2014 | 01:27 PM
fibrepunk's Avatar
Good info, thanks. Btw, how long was the cable?
Old Nov 9, 2014 | 01:30 PM
DArkk's Avatar
Old Nov 9, 2014 | 04:00 PM
SR45's Avatar
Here is one of the better dash cam that I'm thinking of if interested folks. Very good reviews from many sites....
Robot Check Robot Check
Old Nov 9, 2014 | 04:15 PM
DArkk's Avatar
Here is another one that my friend swears by:
Amazon Amazon
It "hugs" your existing mirror. I like the fact it got a built in LCD screen to make sure it's working properly.
Here is the video in action:
Old Nov 9, 2014 | 04:18 PM
NotBlake's Avatar
Robot Check
No offense but that looks like a re-badged g1w which is pretty widely regarded as the industry standard.
Old Nov 9, 2014 | 04:52 PM
Lane03's Avatar
If any of you live in hot climates I would recommend getting a dash cam that uses a capacitor and not a battery, as the heat will likely cause the battery to swell and damage the camera.
The G1W is available with a capacitor and you can swap out the battery in the Mobius with a capacitor. Both are great cameras in the $60 price bracket.
For good info on dash cameras check out: https://dashcamtalk.com
Old Nov 12, 2014 | 01:55 AM
MTLian's Avatar
Wow. The footage from those dash cams is definitely not up to snuff in my opinion. My iPhone 4 does waaaaay better, IMO. If you can't read plates, it just isn't clear enough for me.
Old Nov 12, 2014 | 03:09 AM
SR45's Avatar
Read up on the reviews of this dash cam and you will see its rated at the very top of most of them.
Here is one
another
http://dashboardcamerareviews.com/5-...-cameras-2014/
Old Nov 12, 2014 | 10:44 AM
Lane03's Avatar
The DOD units are very good dashcams. Not sure of that particular model, but I know one of their units uses the exact same chipsets as the G1W. The big difference was the DOD unit's firmware was more refined and had additional options. You could actually flash the G1W with the DOD firmware, but finding the DOD firmware can be a challenge as they don't make it available to customers - only vendors.
Old Nov 12, 2014 | 01:45 PM
Bassguitarist1985's Avatar
I ran my wire on the drivers side A piller. I added an add a fuse kit with a 5 amp with a an accessory plug and plugged the lighter cord into it. It is powered by the ACC bus, meaning it shuts off power when ignition is off. It frees up my front accessory outlet for other stuff and looks clean too.
USDM
Car Shows, Events, and Racing
Feb 3, 2019 01:07 AM
Previc93
Aug 16, 2017 12:18 AM
Shockwave199
May 23, 2014 08:50 AM
cjecpa
Apr 12, 2013 12:04 PM
cjecpa
Aug 7, 2012 08:04 AM
