windshield washer adjustment?
Old Jan 11, 2015 | 02:50 PM
rodney's Avatar
my windshield washer nozzles spray too low. i find myself using way to much fluid to try and clean the window at speed. i used to be able to adjust previous honda's washer nozzle's with a pin, rotating the ball in seat to get the proper spray pattern.
i could not find anything about adjustment in the manual. I just checked out the car. it was a little tough to tell, but i thought the washer possibly could be rotated with a screwdriver. not sure if it was my mid teens weather, but it did not move. i didn't want to break it, so did not force the issue.
anyone know if the windshield washer nozzles are adjustable?
Old Jan 11, 2015 | 09:48 PM
Bassguitarist1985's Avatar
Im curious on this. Ill research this too.
Old Jan 12, 2015 | 05:27 AM
cookiemech's Avatar
I'm wondering the same thing, because it looked to me as though the driver side was spraying pretty low. Passenger side didn't matter to me at the time (since I was driving), but it looked OK.
Old Jan 12, 2015 | 07:18 AM
I have the same exact issue. Ill look at the nozzle later today. It has to be adjustable im thinking. If its non adjustable thats stupid.
Old Jan 12, 2015 | 09:54 AM
cheesewhiz's Avatar
Poorly Aimed Pisser
I'm glad someone brought this up ... thought it was just me. I will check it out as well.
Old Jan 12, 2015 | 10:08 AM
CyclingFit's Avatar
Very happy to see this topic. I only use the spray when stopped.. If not, I'm lucky to clear the wiper blades.
Old Jan 12, 2015 | 09:58 PM
albertaFIT's Avatar
Same problem for me, especially on the driver's side. Also, when I pull forward on the handle to mist the front windshield, some wiper fluid leaks out the nozzle on the rear window. This is annoying! Anyone else?
Old Jan 12, 2015 | 10:32 PM
psuguy's Avatar
I have wonderd this same thing too! It annoys me. Anybody have any idea about it?
Old Jan 14, 2015 | 01:45 AM
Bon Bon's Avatar
Unhappy Low spray
Yeah, me too!
Old Jan 14, 2015 | 06:22 AM
rodney's Avatar
i was looking at it again yesterday, and i do not think it is adjustable. it is 4 degrees right now, so i am not going to try and take it apart yet. i was hoping someone in a warmer climate could try...
the plastic cowl the sprayer nozzle is housed in, moves fairly easily. i was thinking of shimming the cowl up, thus moving the sprayers. if the nozzles are in fact non adjustable, then that will be our only option.
Old Jan 14, 2015 | 08:57 AM
Yeah I'm in the same boat too Rodney, its around 8 degrees outside now. I quickly looked at the nozzles and they do seem like they are fixed. I was hoping for some sort of ball and socket design that allows adjustment. Once I have a chance to really analyze it I'll report back. If the cowl can be shimmed then at least its something.
Old Jan 14, 2015 | 11:30 AM
mahout's Avatar
yes they are. with a straight pin, which is also how you clean them.
Old Jan 14, 2015 | 01:19 PM
Confirmed you can adjust with a small pin. Here is a picture
Old Jan 14, 2015 | 02:26 PM
Vanguard's Avatar
Good to know!! Thanks for the information!
Old Jan 14, 2015 | 02:34 PM
GotFitB13's Avatar
Mine seems to change depending on the weather. Originally it always seemed low. But I think with winter maybe ice and snow have worked its way into the sprayers because at least for a while I was getting full spray coverage.
Old Jan 14, 2015 | 04:57 PM
cookiemech's Avatar
Thanks so much for checking this out. I was a bit loathe to trying this approach, concerned that I might break something. Good deal.
Old Jan 14, 2015 | 09:04 PM
Anytime guys always glad to be of help love this forum!!
Old Feb 21, 2015 | 07:23 AM
cranraspberry's Avatar
Planning to try this out today - any advice on how not to break anything?
Old Feb 21, 2015 | 11:26 AM
stephenmarklay's Avatar
Mine too. I sounds like that Honda set it low on the drivers side. I will adjust mine also.
Old Feb 21, 2015 | 11:59 AM
CyclingFit's Avatar
Whatever you stick in the nozzle, dont just twist it like it's a shifter. Finess is all i can say. Mine popped like they ratchet in there. One click up on both sides went from the bottom of the window to the top.
Goid luck.
