Went past zero range on the fuel gauge
Old Mar 24, 2015 | 11:52 AM
Stingray's Avatar
Originally Posted by MyFreakFit
Says the guy posting useless garbage on an internet forum.
Really? You are aware, or maybe you are not aware, that when you let the gas get too low, below 1/4 tank, you are depriving the fuel pump of its coolant, which is gas, and you suck whatever debris is in the tank into the filter? Let us know the cost of a new fuel pump.
Old Mar 24, 2015 | 11:54 AM
Stingray's Avatar
Originally Posted by kenchan
yah, i do wish sometimes that the tanks on these cars are bigger..but then i suppose it's a trade off with all the added weight, etc.
i only do about 6k miles on my GE so it's not a huge issue for me... at least after you pump the gas to full you see a cheap bill on the receipt and kinda makes you feel better. haha
Bigger? Why? I can go from Phoenix to LA on one tank and still have gas left over. 5 hours. How much farther can you drive without a break!
Old Mar 24, 2015 | 12:02 PM
Fit Charlie's Avatar
Some parts of the country don't need much coolant these days.
Old Mar 24, 2015 | 12:08 PM
GoBucky's Avatar
Probably shouldn't wake up that sleeping dog. That discussion would go on forever...........again.
Back to topic.
Old Mar 24, 2015 | 01:51 PM
haha!
yah, i was talking more surface road driving for daily...
Old Mar 24, 2015 | 02:13 PM
Stingray's Avatar
haha!
OK, that makes sense.
Old Mar 24, 2015 | 02:31 PM
GeorgeL's Avatar
This is not true for two reasons:
1. The pump is drawing from the low part of the tank which is were the debris and water will tend to accumulate. Running the tank low doesn't change this.
2. The pump is cooled by the fuel it draws through itself, not the fuel surrounding it. As long as there is fuel to draw there is plenty of cooling.
Now, if you run the tank dry the pump might be damaged by running without a load. I don't recommend this, but as long as there is gas for the pump to draw you won't have a problem. I routinely run my tank below a gallon remaining and have never had a problem.
The difference is in stopping for that break were I want
versus where there is gas:
Old Mar 24, 2015 | 02:52 PM
MyFreakFit's Avatar
Exactly. It's much easier and productive to plan stops in advance knowing the detailed capabilities of the car than to just wing it based on misinformation.
Old Mar 24, 2015 | 03:32 PM
GeorgeL's Avatar
It's even easier if the car has greater range capabilities. During the Energy Crisis of the '70s I had a Datsun 510 with 25 gallons of fuel capacity. Having a range of over 600 miles was liberating both for local driving and long trips.
Unfortunately, getting large fuel capacities with a Fit is much more difficult.
Old Mar 24, 2015 | 06:35 PM
Stingray's Avatar
Hmmm...in my auto tech school,, what I said was listed as correct.
Old Mar 24, 2015 | 07:31 PM
GoBucky's Avatar
Another issue with increasing the tank size is that the Fit already utilizes existing space about as efficiently as possible. If you add 5 gal to the tank, that cubic footage will have to come from somewhere else.
Old Mar 25, 2015 | 12:24 AM
  #32
Stingray's Avatar
I agree. I go as far in the Fit as I do in my 18 gal Camaro. I fill up once a week. (I rotate the cars each week) difference is, the Fit costs half as much to go the same distance. I don't mind stopping at QT once a week and getting a drink after the fill up. Can't imagine having a problem with that.
Old Mar 25, 2015 | 05:18 AM
  #33
Evesowner's Avatar
The current tank is under the driver's seat, right? Is there some room under the passenger seat as well?
Old Mar 25, 2015 | 02:10 PM
  #34
GeorgeL's Avatar
5 gallons is 0.66 cubic feet, or a rectangular tank measuring 20x20x5". Not a huge package to accommodate.
A bigger issue is weight. That extra 30 pounds and the structure to carry it around would probably cost a bit in mileage and performance.
It would be interesting for one of the automakers to suddenly offer a tank that is markedly larger than the competition. How many people would be attracted by not having to fill up as often?
Old Mar 25, 2015 | 02:32 PM
  #35
Another two gallons would make my life a lot easier. Even one gallon would help most weeks.
Old Mar 25, 2015 | 04:06 PM
  #36
Evesowner's Avatar
Of course a more accurate calculation of the fuel bars and distance left would go a long way. I won't push it to see how close I can get to a true empty tank. So I expect the computer to continue tell me I am nearly out (1 bar and less than 10 mile left) when I fill up again...and then only fill up 8.6 gal. I'd much rather it tell me I have enough miles left for the 2 gals I really have left instead of the bizarre fantom amount it thinks I have
Old Mar 26, 2015 | 05:24 PM
  #37
Stingray's Avatar
If it is that important to someone, they could always have a second tank installed. I had a friend who did that in a Caddy awhile back. He was really proud of how far he could go. Of course, it handled like a pig, and wouldn't out run a moped with all that weight, but he could sure go a long way without a fill-up!
Old Mar 26, 2015 | 05:39 PM
  #38
GeorgeL's Avatar
My god, how big was that tank? Even a doubling of the Caddy's fuel capacity would only add 120 pounds of weight, an amount that most drivers wouldn't even notice in a Caddy.
Old Mar 26, 2015 | 06:44 PM
  #39
Stingray's Avatar
25 gallon tank, on top of what would probably have been a 25 gallon tank that came with the car. Low, to the rear and certainly not good for the balance. 50 gallons at 6 lbs a gallon...300 pounds of fuel. Nobody said he was too bright...and can you imagine the fireworks if he got rear ended?! Remember, those late 70's early 80's GM cars were dogs under the best of circumstances
Old Mar 26, 2015 | 09:21 PM
  #40
GeorgeL's Avatar
A caddy Coupe de Ville tips the scales at 4400 pounds. 25 gallons of gas would increase this by about 150 pounds to 4550 pounds. The trunk is hardly an ideal location for this weight but a road barge like this should be able to handle it without sagging.
A weight increase of 3% would decrease acceleration by the same amount. I doubt that a driver would notice it at all.
I did a similar thing by adding 12 gallons of capacity to my Datsun 510 which weighted just a bit over 2000 pounds. I couldn't tell the difference between full and empty for both tanks and the Datsun certainly didn't have a V-8 to haul it around.
