Battery Upgrade Options
Old Sep 3, 2015 | 07:08 PM
payluder's Avatar
Exide 51R drops right in with just minor mod to the battery tray.
Old Sep 5, 2015 | 08:43 AM
Wallygator's Avatar
Originally Posted by Sqeclipse
I Installed XS Power S975 using the battery post that came with the battery. I used the OEM battery brace. But the OEM battery is like an inch taller then the XS Power. I had to extend the thread a little more to make it fit. The stock grounding wire fits, but i upgraded with 0 gauge wire.
Great thanks! Here is search I did on their website for the battery you used. It has 525 CA. Very nice. Also scroll down for a sweet FIT build and a picture of the battery installed.
Search for "S975" - XS Power
This link shows the price...it ain't cheap.
http://4xspower.com/shop/s-series/s975/
Old Sep 5, 2015 | 08:49 AM
Wallygator's Avatar
Here are the specs on your battery. Another good option for more power.
Exide AGM Car Battery (Group 51R)
Old Nov 21, 2015 | 08:19 PM
HarleyBadger's Avatar
I updated my fit with a XS Power battery. Perfect Fit.
What year Fit?
Old Nov 21, 2015 | 10:03 PM
TofuShop's Avatar
Your stalling issue is due to the location (closeness) of your ballast in relation to the ECU in the engine bay. Move your ballast as far forward (towards the front of the car) as possible and away from the ECU. Either tuck it and have it blocked by the battery or install it behind the bumper by the crash bar. The discharge when your ballasts ignite sends a wave that disrupts your ECU causing the temporary blip and wanting to stall.
Old Nov 22, 2015 | 12:38 PM
rodney's Avatar
thank you for this, it is very much appreciated!
Old Nov 23, 2015 | 02:52 PM
frank438's Avatar
I concur with your findings. My wife's 2008 fit is already on its 4th battery. The dealer told us this battery was an unusual size and only Interstate makes them and then they slap a Honda label on them. (I tried to get a Die Hard with no luck because it is a unique size per Sears)
No car should not start because you accidentally leave the dome light on during the work day (had this happen) or overnight (had this happen too). These batteries are subpar in my opinion. I feel for folks in extremely cold climates that have these cars - winter must be unpleasant for them.
Old Nov 23, 2015 | 06:01 PM
dwtaylorpdx's Avatar
For not much more than the interstate there are several options, Odessey being one of them, interstates gell/encapsulated battery is another, about 2x the cca for either one in the same physical size.. .
Old Nov 25, 2015 | 07:09 PM
2Rismo2's Avatar
I left one of the map lights on overnight, at least 12 hours, over the weekend and was glad the car started. I had changed to led bulbs so maybe that helped.
erichyung
Mar 16, 2026 04:11 PM
Jensen Healy
Dec 6, 2019 02:54 PM
Zero2Hero
Feb 9, 2019 10:03 PM
setter11
Feb 27, 2009 05:40 PM
Remco
May 4, 2005 11:16 AM
