First Oil Change @ 8,000+ miles? Anyone else?
Old Oct 15, 2015 | 12:51 AM
ChazLyle's Avatar
I don't know how much I trust the Oil Life meter, and I certainly have driven basically only highway miles but @ 5,400 miles the meter just finally rolled back from 60% to 50%.
I bought the car in late July and drove across country/to a few national parks, etc.
I am wondering if anyone else experienced their first oil change timing (Oil Life showing 15%) with pretty high miles.
I'm guessing I'll be at around 8,000 or more when it gets to 15% and I'll likely get it changed before then. Just curious if this is a common happenstance.
Old Oct 15, 2015 | 01:58 AM
2015FIT's Avatar
See these two threads (there may be others). You can see what mileage others have been getting prior to reaching 15% oil life. And, yes, I think that around 8,000 miles or more is a common happenstance (driving conditions and style will dictate a lot of it).
https://www.fitfreak.net/forums/3rd-...il-change.html
https://www.fitfreak.net/forums/3rd-...indicator.html
Old Oct 15, 2015 | 02:19 AM
ChazLyle's Avatar
Thanks. Read the latter but not the former.
I tend to just look at the oil itself and decide ha but it's nice to know this is the norm. Definitely does better than my 1993 Toyota Pickup.
Old Oct 15, 2015 | 02:36 AM
ezone's Avatar
I see the minder system allow anywhere from 4000 to over 12,000 miles on an oil change, it all depends on how the cars are driven and the conditions you drive in.
All you really need to do is check the level once in a while, make sure it isn't empty.
My daily commute is only 5.5 miles each way, if I stick to that my car lets me go about 5k before telling me to change oil.
Old Oct 15, 2015 | 08:00 AM
Uncle Gary's Avatar
I did my first oil change in the GK at 8,400 miles with 20% oil life remaining. IIRC, the first oil change on my GE was near 10,000 miles @20% oil life remaining.
The OP's case seems typical. Although Honda won't tell us the parameters it uses to measure oil life, I can guess they use a combination of total engine revolutions, number of cold starts, average ambient temperature, and probably some other factors to calculate oil life.
I don't know how anyone thinks that "looking at the oil" can tell you more. Simply turning dark is meaningless. ALL modern detergent oils will turn dark fairly quickly, as they're designed to hold small particles in suspension. This means the oil is doing its job, carrying off suspended solids instead of leaving them inside the engine as sludge.
Old Oct 15, 2015 | 02:02 PM
ezone's Avatar
^Truth...^
Old Oct 15, 2015 | 06:15 PM
Oneoldphlaytis's Avatar
15% @ 10,442 miles
[QUOTE=ChazLyle;1323408]
Old Oct 15, 2015 | 07:46 PM
kbonus's Avatar
Mine was about 10K miles, give or take.
Old Oct 15, 2015 | 08:10 PM
Gregg's Avatar
My LX-CVT reached 15% at about 8400 miles.
Now have about 12,000 miles and it just turned 60%.
Gregg
Old Oct 18, 2015 | 01:46 AM
KikeDiaz's Avatar
I do a lot of short trips less than 1 miles so I enter into a hard condition maintenance. But my fit does not have car mainance. And in the book it says I should change the oil every 3 miles and full service every 6 miles that based on this site is ludacris.
Do you suggest changing oil every 5 miles in hard condition?
Old Oct 18, 2015 | 10:04 AM
ezone's Avatar
You seem to be in Mexico, I'm not familiar with vehicle differences in that market. Maybe the recommendations are different from the US?
Is the oil available there identical to the oil available in the US?
Is your car older, before Honda started using the maintenance minder system?
Is your car equipped with a "maint req'd" (or just says "maint") light instead?
If you do short trips less than one mile, you may not reach 3000 miles in one years time and I would hope your manual would say to change oil at 6 months or one year (or similar time based recommendation) even if mileage has not been reached in that time.
HTH
Old Oct 18, 2015 | 07:46 PM
gweeper64's Avatar
My first oil changed was at >9000 miles. I have a long, mostly highway commute so I wasn't too worried about it.
Old Oct 19, 2015 | 02:02 AM
ChazLyle's Avatar
I've owned nothing but 4WD pickups my whole life. Drove only short trips and in harsh winters. Barely put on 9,000 miles a year, 10 if I drove a lot. Worked em hard and off roaded a bit.
This is not only my first car ever, but also the first time I've put on nearly 6,000 miles in less than 3 months haha. So it's a big change for me.
The hardest part is not being able to take any beat up road, drive over any obstacle or pull anyone out of wherever they're stuck. Spent a few days in National parks on the way out and about 10 days in Yosemite NP once I got to Cali and I pushed this thing down some roads until I was bottomed out and nicking the clear coat on bristle before backing out haha I really need to learn this whole not having at least a foot of ground clearance and armor thing... As well as less frequent oil changes.
Old Oct 19, 2015 | 10:57 AM
Fit_as_a_butchers_dog's Avatar
I have like 2,000+ miles on the Fit and an inbox full of emails from the dealer to hurry up and get maintenance done on my car. What the heck for? The car has been bullet proof so far.
Old Oct 19, 2015 | 12:55 PM
robbbbb's Avatar
Mine hit 50% at a little over 3500 miles and 40% at a bit over 4200 miles, so it seems on track to hit zero at 7000. So I'm planning on an oil change somewhere in the low 6000's.
Old Oct 20, 2015 | 10:51 AM
yesles's Avatar
I reached 15% oil life at approx 6,300 mi; and I drive on the weekends only for errands and road trips
Old Oct 20, 2015 | 02:56 PM
thedrummingfish's Avatar
I do mostly freeway travel and my MM didn't light up until after 10k...
Old Oct 20, 2015 | 09:37 PM
dwtaylorpdx's Avatar
Oil testing is your friend Honda (Nor any other maker) has no reason to help your car last beyond the warrantee..
Old Oct 20, 2015 | 10:02 PM
festiboi's Avatar
I'm at 3500 miles and 50%. But....this week is one year since I bought the car, so the way things are going, it'll be two years before the first oil change
Old Oct 20, 2015 | 10:04 PM
xxryu139xx's Avatar
honda recommends to change the oil at least once a year.
