6MT Shifting Recommendations for best fuel economy: Eco Assist or Honda Manual
Average mpg is what you want it to be. If you reset the average every time you fill the tank, it's a tank average. Tank mpg and short trip mpg work together to show what you're doing now and how it affects the tank.
(Hypermiling would be to shift to neutral while turning the engine off, so you don't have the extra resistance from being in gear but you're also not burning gas to keep the engine idling. Most people view this as excessively dangerous and not worth the fuel savings, which I agree with, but it's not the point of this reply, so i don't propose it as an option 3 above.)
It all comes down to knowing why you're doing what you're doing.
I have an MT and try to glide on neutral when going downhill to increase mpg, however, this advice from someone who posted on Fuelly Fuel Saving Tips suggests differently. What are your thoughts, neutral or highest gear when going downhill?? Is it different between MT and CVT??
"While going downhill, don't drive in Neutral gear. Instead drive in the highest gear and don't put your foot on gas. This will prevent the vehicle from speeding and at the same time reduce fuel consumption as compared to the case when you drive on neutral and the fuel is constantly being fed to the motor for idling. This will reduce the braking as well."
If (on flat or slight decline) or (on a steep decline and you do not want to accelerate)
---stay in gear, DFCO will save you idle gas;
elseif (on a decline that will accelerate car above current speed)
---coast. You will waste idle gas but increase forward momentum;
endif
I guess it really does depend on your situation. Every little bit helps though, so I'm paying attention to these little details.
Coasting in gear is engine braking. If braking is appropriate, that's the way to go. If braking is not appropriate, the bit you burn idling is still better than braking.
Idling at 60 mph, my Fit gets around 270 mpg. I could make that number look higher by engine braking, but it's just a stunt that would make me burn more gas over the whole trip. Braking in any form is best avoided whenever possible.
wsalopek
Apr 12, 2006 12:18 AM
