First oil change, any suggestions?
Old Dec 18, 2015 | 12:55 PM
carrier's Avatar
I will have had my FIT for a year in January. Have really low miles (2500) and the oil gauge says its at 40%. I plan on changing it in January, regardless.
Old Dec 18, 2015 | 03:49 PM
exl500's Avatar
Me too. Changed at one year and 4500 miles. So annual per the manual.
Old Dec 20, 2015 | 03:20 PM
bach's Avatar
What happens if you keep driving after the 15% wrench? Does it drop to 10%, then 5% then zero, or is 15% the bottom?
Old Dec 20, 2015 | 03:31 PM
Black3sr's Avatar
Engine seizes. Just RTFM and follow it.
Old Dec 20, 2015 | 03:40 PM
Carbuff2's Avatar
Seriously, it drops as stated, to 10%, then 5%, then zero.
Old Dec 20, 2015 | 04:49 PM
doctordoom's Avatar
Supervillain
And then negative numbers after 0%
Old Dec 21, 2015 | 09:22 AM
jhn's Avatar
jhn
I think if you drive it at 0 for an extended period of time the ECU will go into limp mode.
Don't forget to reset it!
Old Dec 21, 2015 | 09:46 AM
Oneoldphlaytis's Avatar
Actually it says annually AFTER the mileage minder has been RESET. So when it is new it has never been reset yet. Seems to me that the manual/honda says leave the the initial fill in 'till the MM says 15% regardless and not to change it early.
But reasonable minds may differ...
Old Dec 21, 2015 | 12:16 PM
exl500's Avatar
It sure does say that. Too bad they didn't make it clear. Wonder which is really right?
Anyway, can't get my oil back.
Old Dec 21, 2015 | 01:22 PM
fiddlesticks1's Avatar
Synthetic oil
I have a 2007 Fit Sport MT with just under 255K . I use Mobil 1 with the Mobil 1 oil filter with 5K oil change. Engine does not burn oil or leak.
Old Dec 21, 2015 | 02:08 PM
Carbuff2's Avatar
Boys Boys Boys
You are not going to damage or cause excessive wear on your engine whether you change the initial fill oil at 1000 miles or 10000 miles.
Used oil analysis on BobIsTheOilGuy.com indicates that the 'extra ingredient' in Honda factory oil is Molybdenum, but even that is suspect, because this stuff is often used to coat the moving parts of internal combustion engines prior to first start-up.
Some folks (including me, many years ago) used to put this substance in their oil. You can still buy it as an additive if that floats your boat.
Old Dec 21, 2015 | 04:38 PM
  #32
exl500's Avatar
Hey, I'm just peeved I may have wasted my first comp oil change ;-)
Old Dec 21, 2015 | 09:06 PM
  #33
laughter95's Avatar
The manual says to do the first change at 15% as part of a proper engine break-in procedure. Why do otherwise?
My lifetime powertrain warranty requires that I follow maintenance in accordance with the maintenance minder.
Old Dec 22, 2015 | 01:33 AM
  #34
MTLian's Avatar
Just throwing this out there:
Fumoto valves are pretty cheap and they make a nipple/hose model to which you can attach a hose to the drain plug and drain right into a waste container or empty bottle of your choosing. Rather than risk losing the splash shield completely, how bout trying to dremel a small section to access the valve and use a hose and then attaching the splash shield more permanently with zip ties or what not. Could be a solution...
Old Dec 22, 2015 | 05:21 AM
  #35
BeauDiddley's Avatar
Great idea! I've been wanting to put a Fumoto Valve on our Odyssey but keep forgetting to order one. Now I need to order for the Odyssey, Fit, and maybe even my motorcycle if it makes it easier.
Old Dec 22, 2015 | 11:12 AM
  #36
Press Fit's Avatar
Old Dec 22, 2015 | 06:21 PM
  #37
dwtaylorpdx's Avatar
The "new" green oils are very very low on Zinc Sulfide (I think thats the chemical..) its primary purpose is to facilitate the surface hardening of your cam and tappets/followers.
Several sources now sell high zinc/moly content oils for break in purposes. Its not good to run it indefinitely because it fouls the new 3way cat converters under extended use.
Joe Gibbs has several blends for breakin oils. Others do as well, or you can add the additives like Lubri-Moly. (Which funny enough really does not have much molybdenum in it. ) Zinc and Sulfur are your engines friends at break-in time.
Since the mandated change in oil formulas lots of racers were having cam failure problems on new engines, Compucams used to have a good writeup on it..
I've seen small bloc V8 engines eat a cam in 15 minutes when not broke in properly..
Cheers
Old Dec 22, 2015 | 06:50 PM
  #38
Always remember,, OEM recommendations protect them under the warrantee ,, the first click of the odometer after that Honda won't give a **** about your car, so some recommendations I take with a grain of salt. Toyota recommended 15K oil changes on the 1985 pickups.. The 22R would literally start tapping at about 4K on the oil, LOUDLY and when you drained it it looked awful can't imagine what 11K more would have made it look like..
Old Dec 22, 2015 | 10:52 PM
  #39
oiric2006@gmail.com's Avatar
Originally Posted by Press Fit
This does help but you still have to remove the splash shield to replace the oil filter.
Old Jan 2, 2016 | 10:28 PM
  #40
bach's Avatar
I got my first change this morning, the odometer was 7526. The gauge dropped to 15% at almost exactly 7000 and hit 10% at about 7400 or so. It will be interesting to see if the straight 0w20 lasts as long as the break-in oil.
