Additional fix for coil pack problems
Old Jan 6, 2016 | 11:19 AM
Stingray's Avatar
Still had intermittent mis fires after the coil packs were replaced. Dealer contacted Honda, and they are going to put new injectors in, and adjust the valves. Might want to see if yours needs the same if it continues to misfire after the coil pack recall
Old Jan 7, 2016 | 05:14 PM
CommanderSlug's Avatar
Dealer replaced my injectors along with the coil plugs. But they did so due to my check engine light (misfire), not due to the recall. So I think that the recall will be a hit and miss. Some will fix the misfire issues, some will require injector replacement. Funny thing is they also replaced part of the fuel system as per service bulletin.
After all was said and done, misfires went away and so far I had a good check-engine-light free 10k miles. I am at 27,000 miles now.
Flyboybob
Oct 3, 2015 09:29 PM
Mtwalenciak
Dec 23, 2014 10:04 AM
dtgrosse
Jul 17, 2014 01:04 PM
codenamezero
Mar 2, 2014 04:00 PM
jaymiepaige
Feb 25, 2007 03:53 PM
