Reading Fuse Box Chart
Old Jun 24, 2016 | 01:48 PM
LarryS's Avatar
2016 LX --- Having some difficulty resolving the fuse box layout chart with the actual fuse locations (see atch). The Fuses are a 6 x 7 matrix (with 4 upper relays) while the chart doesn't seem to correspond.
For those of us who are too literal (or simple-minded), is there a better (or easier) description?
I want to plug in an "add-a-fuse" to an ignition-switched circuit for a very low power application (auto dimming mirror).
Thanks.
EDIT: Never did figure out the chart in the photo, but using Page 423 in the Owner's Manual and comparing to fuse amp values the fuses are defined starting at top left reading down (#1-7), then beginning again at the top of column 2 (#8-14), etc. Looks like I can add my 'add-a-fuse' to one of the power window fuses (#8-11) to get a switched circuit.
Old Jun 24, 2016 | 03:19 PM
dwtaylorpdx's Avatar
FWIW ,, my 07 has at least 2 connectors for random accessories that were available form the factory 1 was near the stereo harness, one was on the fuse box, connecter was labeled "m" and seemed to be for dealer installed accessories like alarm on car that came without ,,, stuff like that.
Old Jun 24, 2016 | 03:29 PM
LarryS's Avatar
Even better if I could find something like that on the 2016! There is an "option" 10A fuse at position #39, but no indication of where one would pickup that circuit.
Dedroberts
Jul 22, 2018 12:52 AM
SilverEX15
Jul 30, 2015 03:30 PM
TWGE08
Jun 10, 2009 07:54 PM
FitLIKEaGlove
Feb 17, 2007 11:52 AM
sLiVeRwOrM
May 13, 2006 11:02 AM
