Question about maintenance
Old Jun 25, 2016 | 10:05 PM
exl500's Avatar
My Fit is due for its second maintenance visit. I'm reading page 359 in the manual, and I'm confused as to what the dealer is supposed to do. It looks like "B" under the main items (am I correct?), but I don't get what of the sub items are to be done...1 & 2? I'd like to be sure before scheduling. Thanks.
Old Jun 25, 2016 | 11:01 PM
BenQuick's Avatar
Is the Maintenance Minder calling for you to service the car or are you doing this on your own?
At 8500 miles, I chose the dealerships 10,000 mile service which equates to main code "B" and sub code "1". It was $42. My maintenance minder wasn't displaying any codes. With my crazy schedule, it was just a good time for me to get it done.
If it's only your 2nd visit, you may not need the sub code 2 items done just yet.
CODE Maintenance Main Items
A  Replace engine oil *1
B  Replace engine oil and oil filter
 Inspect front and rear brakes/service as necessary
 Check parking brake adjustment
 Inspect tie rod ends, steering gearbox, and boots
 Inspect suspension components
 Inspect driveshaft boots
 Inspect brake hoses and lines (Including ABS/VSA)
 Inspect all fluid levels and condition of fluids
 Inspect exhaust system #
 Inspect fuel lines and connections #
CODE Maintenance Sub Items
1  Rotate tires
2  Replace air cleaner element *2
 Replace dust and pollen filter *3
 Inspect drive belt
3  Replace transmission fluid
4  Replace spark plugs
 Inspect valve clearance
5  Replace engine coolant
Old Jun 25, 2016 | 11:15 PM
exl500's Avatar
Thanks for your reply. My car is low mileage, so I'm taking it in since it's been a year since my first (annual) visit. I just broke 11k miles in 2 years...we're retired, and we walk a lot.
Old Jun 26, 2016 | 07:10 AM
BenQuick's Avatar
Walking is good. I need to walk more to get rid of this gut of mine.
After 11,000 miles and 1 year, I would just do the oil/filter change and tire rotation. This should all be included in the cost - plus washing your car. They might do a complete inspection also where they check everything and I mean everything. I had a 4 page printout of all the work and checks that they did. They were also aware of the splash guard fastener complaints and didn't need the spare ones that I brought. I was impressed. They did a good job and I was out of there in 45 minutes.
Old Jun 26, 2016 | 07:19 AM
exl500's Avatar
Thanks again. Makes sense, and I'll do just that.
Oh, and walking a lot doesn't mean we don't find ways to put that weight right back on!
Old Jun 27, 2016 | 12:40 PM
jhn's Avatar
jhn
I just did my oil and filter (3rd time since purchase), transmission fluid, complete bleed and flush brakes (2nd one), rotated the tires and inspected everything, all in my garage this past weekend. 18k miles.
It's about $75 and some elbow grease (for all the fluids and filter) to do it yourself.
Old Jun 27, 2016 | 12:55 PM
exl500's Avatar
Thanks. It's been so long since I worked on a car - the mid-70s - I wouldn't know where to start, and no doubt cause more monetary damage than the money I'd spend having the dealer do it. Since I've only spent $50.00 in maintenance items so far, I'll live with the bill.
Old Jun 27, 2016 | 02:26 PM
2Rismo2's Avatar
Is there a way to find out what the upcoming maintenance would be? I'm at 30%, but just trying to have the materials on hand when it comes up.
Old Jun 27, 2016 | 03:33 PM
BenQuick's Avatar
I could be wrong, but I think the maintenance minder will alert you when your oil life is at 15%. Also, if you're getting near the 30,000 mile mark, your cvt fluid may need changing. So for now, the materials you need should just be the motor oil and filter. Plus rotate your tires if need be. And maybe a new air filter. That's all I can think of.
Old Jun 27, 2016 | 03:51 PM
2Rismo2's Avatar
Yup, you'r right. It gives you a reminder at 15% of what's needed. I drive 85 miles round trip for work so I put the miles on pretty quickly. I just wanted an extra time to get the parts. Last I looked I was at 27k and I've already done the air filter and cabin air filter at around 18k so I should be good for a while. I think I'll pass on the CVT fluid till the MM says so. I think 30k might be overkill personally for that service.
Old Jul 5, 2016 | 02:47 PM
exl500's Avatar
I made the appointment today. The service guy confirmed it will be a tire rotation, oil and oil filter change, plus the door handle recall.
After I got off it occurred to me: What about the cabin air filter?
Thanks again for the advice up thread.
Old Jul 5, 2016 | 03:21 PM
BenQuick's Avatar
They run about $23 at the dealership. I just ordered a Fram FreshBreeze filter for $14 on Ebay. I don't need one just yet but for that price I went ahead and bought one.
Old Jul 13, 2016 | 03:50 PM
exl500's Avatar
Everything was done for just over $60, which I found very reasonable. Thanks for all your advice.
PatrickT
Nov 30, 2024 08:31 PM
SilverEX15
37
May 21, 2018 01:12 PM
hardac
Aug 26, 2008 03:34 PM
hqly
Jun 24, 2008 01:38 PM
wyy183
Dec 2, 2006 03:41 PM
