Humming noise on road: Is it the tires or the wheels?
Old Jul 24, 2016 | 12:03 AM
salamlaith's Avatar
on/off Humming/buzzing noise over 65mph
I noticed a "humming" noise in a kind of off-on-off-on manner, when I drive over 65 mph
it's like 1 second humming, 1 second off, 1 second, 1 off .... and so on.
no vibration, tried deferent roads .. same sound.
I tried to jack up one front wheel and drive it like I do with old cars to check if its the bearing sound , it didn't work ... unlike old cars the other front wheel wants to drive too!, I jacked the both front wheels still didn't work either, the ESC stability system is breaking, I turned it off, it didn't help.
I did grasp the tire at the 12/6 position and tried to rock the tire and wheel in and out, no play.
have you experienced anything like that ?
it's a Honda Fit 2016 that as only 2k on it!
Old Jul 24, 2016 | 01:14 AM
KTFitYEAA's Avatar
I know what you mean!!! I hear it too!!! Thought it was my aftermarket wheels...wow! This is weird!
Old Jul 24, 2016 | 02:52 AM
salamlaith's Avatar
do you still have this sound ? was it there before putting the aftermarket wheels ?
Old Jul 24, 2016 | 02:53 AM
kgb4187's Avatar
If the noise happens on different road surfaces it's the car, if the sound isn't constant I wouldn't think it was the wheels. Does the sound happen with the A/C on or off?
Old Jul 24, 2016 | 03:00 AM
KTFitYEAA's Avatar
I think I still have the sound...although my car always has music playing.
I have no idea if it was before or after. But I get the sound.
Old Jul 24, 2016 | 12:57 PM
i wonder if it's caused by the wind and one of ur body panels are loose? have u checked the engine shroud? maybe it's coming undone, not sure.
if it was bearings it would be a constant sound at those speeds.
Old Jul 24, 2016 | 04:09 PM
salamlaith's Avatar
sound happen all the time over 65mph, it didn't make any deference turning on/off the AC
Old Jul 24, 2016 | 04:15 PM
salamlaith's Avatar
AGREE, trebled bearings makes constant sound and the sound starts over 40mph.
I noted today that there's a little vibration on the deriver side mirror, same side that the sound comes from.
I think it might be the tire, I will try to rotate the tires.
Old Jul 24, 2016 | 09:48 PM
DrewE's Avatar
I think you're hearing tire tread noise. The tires that came with my Fit were not particularly quiet (nor especially great in any other regard).
Old Jul 27, 2016 | 09:32 PM
salamlaith's Avatar
i did tire balance and rotation, no deference
Old Jul 28, 2016 | 11:27 PM
gallent92's Avatar
What your dealer said about it? I believe it is either the tires or the car itself. Does your passenger hear it too? Getting a better and quiet street tire could solve the problem.
Old Jul 29, 2016 | 12:49 AM
Fuelish's Avatar
I hear a slight wooh-wooh-wooh kinda noise in mine, varies with the speed, but only seems to occur up to 25 mph, and only on certain road surfaces (like my neighborhood)....given my circumstances, I'm guessing my (extremely minor) problem is the tires, which were virtually new when I bought my used '15 in May of this year...Cooper CS3's, they're not stockers - original owner put like 43,000 miles on this car in a year and a half or so. So, am gonna be stuck with these bad boys for a good few years, but hey, have driven far worse tires
Old Jul 29, 2016 | 12:54 PM
salamlaith's Avatar
i don't have warranty on this car.
yes passengers can hear it too.
it only happens over 65mph, it comes with a little vibration, the sound is not loud, but it can be noted.
Old Jul 29, 2016 | 05:51 PM
salamlaith's Avatar
i did alignment today, it didn't help.
how much it cost if I take it to the dealer for checking ?
the car has no warranty, its a rebuild.
Old Jul 29, 2016 | 06:01 PM
DrewE's Avatar
If it's more a humming noise than a thumping or helicopter sort of noise, it's probably the tread pattern on the tires. In that case there's nothing to repair because there's nothing broken; it's simply that particular tire design being somewhat noisy. It's also nothing dangerous--annoying perhaps, but not a sign of trouble.
The solution in that case is to get different tires. Rotating the tires can sometimes help, to some degree, but noisy tires are just noisy also.
I don't know what your dealer might charge you. A good dealer should charge you nothing to tell you that you have noisy tires, or at most a very nominal fee for a couple minutes of diagnostic work. An especially shady dealer might sell you much work that is absolutely unnecessary if they think you're gullible.
Old Jul 30, 2016 | 05:02 PM
Uncle Gary's Avatar
Be thankful you never got to try the stock Firestone tires. I did, and the Cooper CS3s are MUCH better. Quieter, better ride, better handling, and hopefully longer lasting.
I wouldn't recommend the stock Firestones for use as a swing.
Old Jul 30, 2016 | 10:34 PM
bigbacon's Avatar
yea our stock tires are noisy as hell now with 20k miles on them. I've had summer tires last longer than these things and be less noisy after 35k miles or more.
Old Jul 31, 2016 | 02:34 AM
Bob Levine's Avatar
The Firestones on my 2016 are noisy. Otherwise, not too bad for OEM tires.
The worst i've ever seen were the Integrity tires on my Corollas. Dumped them at about 7K miles for Michelins.
Old Aug 1, 2016 | 12:25 PM
salamlaith's Avatar
wheel bearings where checked, nothing wrong with them, did alignment and balance, still the on/off humming sound accrue over 65mph
my 2016 came with Firestones tires.
yesterday I was driving on a highway, one part was newly paved, the off/on humming sound was way quitter on the new pavement, it makes me thing its a tire tread noise, I HOPE
Old Aug 1, 2016 | 01:19 PM
Fuelish's Avatar
Yeah, we had the same "pleasure" with those tires on our Corolla.....utter crap, they were
