Offset question
Old Aug 12, 2016 | 11:48 PM
orataro's Avatar
Offset question
Looking at buying some new wheels for my LX. I would prefer to have the wheels flush with the fenders. Or just within the fenders as I plan to drop it. Anyone know what the best offset would be? Thank you.
Old Aug 14, 2016 | 12:41 AM
KTFitYEAA's Avatar
I have 16x7 +42 all around and it's pretty flush...anything lower imo will poke out.
Old Aug 14, 2016 | 03:08 AM
Vjaramillo's Avatar
I have 17x7.5 sparco drifts. Flush and on lowered fit. Minor rubbing on potholes.
Old Aug 14, 2016 | 08:56 AM
stembridge's Avatar
See my mod thread in my sig - my wheels are 16x7 +40, and the tires would occasionally kiss the fender on big bumps. I've since installed RSR "down" springs (minimal drop) and they are stiffer to the point where I rarely rub any more, despite being lower. I'm also running camber bolts, at -1.5*, which probably helps, too.
es
Old Aug 16, 2016 | 08:27 AM
the rear can use 5-7mm less offset and come out nicely. i ran spacers on the rear when i had my GE. it looks to be the same for the GK as the rear is sunken in more.
example: if your front is 45mm offset, you can run like a 38 on the rears.
adam s
Mar 17, 2024 07:58 PM
mikeGe82012
May 28, 2017 12:11 AM
wuman
May 8, 2017 01:19 PM
Scaldy
May 1, 2009 09:44 PM
allgocrx
Mar 24, 2009 03:33 PM
